Starting over
Old Oct 22, 2010 | 06:47 PM
RedDog382's Avatar
RedDog382
Default Starting over
Have been having an issue with my '05 factory radio jumping between two different radio stations and want to delete everything from preset memory and start over. I tried unhooking the negative terminal on the battery for about 15 minutes, but that didn't delete anything. Is there another way to delete all station memory from the radio ...?
Old Oct 22, 2010 | 07:29 PM
RicK T's Avatar
RicK T
I don't know of a user accessible method. If it's important maybe ask in the Audio Forum.
FWIW, what I would do is just set all the presets to the lowest AM and lowest FM frequency on each band. That would erase what you've been using and you can start fresh from there. Good luck.
