Replacing TPMS Sensor?
Old Oct 27, 2010 | 01:38 AM
Jedsvet's Avatar
Jedsvet
Default Replacing TPMS Sensor?
Does the tire need to come off of the rim or just the bead broken down?
Old Oct 27, 2010 | 06:24 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
It can be done with just the bead off. They just need enough room to pull the old one out and insert the new one.
Old Oct 27, 2010 | 08:22 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
....and maybe it's obvious, but have the wheel re-balanced....
Old Oct 27, 2010 | 08:31 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Not a bad idea, but...
If you replace the sensor with an identical one, and don't rotate the tire on the rim; how would the balance change?
If you remove the tire completely, that would be different.
To Replacing TPMS Sensor?
