Double Sided Tape
Old Oct 29, 2010 | 09:13 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Default Double Sided Tape
I recently bought some pre-owned splash guards and need to get some new adhesive strips for them. I figured I could use some variant of 3m double sided tape, but the only one I could find locally was this 3m Super Strong Automotive Adhesive which I figured if I ever had to remove the splash guards would also remove a line of paint underneath, a la "Super Strong." Anyone know of a product I can use? Afaik, it doesn't have to be strong enough to actually hold the splash guard on, just to keep it snug around the outer edge. Just looking for something paint-safe.
Thanks all.
Old Oct 29, 2010 | 10:35 AM
RULEMKR's Avatar
RULEMKR
St. Jude Donor '09
Some glass companies use a 2 sided tape that seem to work great. I think it's designed to use on wall mirrors or something. It comes in a roll and it only about a 1/4 inch wide. It's been a while since I purchased any but I'm sure the still sell it.
Old Oct 29, 2010 | 10:51 AM
marc8090's Avatar
marc8090
They come with what seems like the super strength 3M stuff, as do most spoilers, front lips, etc, that use double sided tape. As long as you don't violently try to remove it and instead "roll" it off I wouldn't be too concerned about the paint lifting. Besides, once installed, I can't see why you'd ever want to remove them.
Old Oct 29, 2010 | 01:41 PM
sevinn's Avatar
sevinn
Hmm I tend to agree with you about never removing them, I just wanted to be safe. The only reason I'd ever remove them is if I were replacing the fenders with wider ones anyway. I'm just going to go with the stuff I can get locally. Thanks for the advice.
Old Oct 29, 2010 | 03:03 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
If this is the 3M gray foam tape with the red backing, I've used this tape for the Z06 splash guards and experienced no problem removing it without harming the OEM paint. Use lacquer thinner on a rag to help dissolve the glue. I got it at Home Depot.
Auto supply stores have the 3M tape that is designed specifically for body trim and molding. Try Autozone or Pep Boys.
When you attach it, wash and prep the surface with denatured alcohol to remove wax, oil.
Old Oct 29, 2010 | 05:35 PM
sevinn's Avatar
sevinn
Thanks, I'll try to find that, and if I can't I'll go with what I found at WalMart (the stuff from my OP).
To Double Sided Tape
