We can do your differential for you. We have gears on the shelf ready to go. As for doing 3.90s or 4.10s that is WAY too much gear for a 6L80e car. We have found that 3.42s are perfect for a 6L80e. Let me know if there is anything we can do for you.
I have a 2011 c6 base coupe 6l80 a6 tranny. Need some better get oft corner on track days without always going down into 2nd gear. I have been advised that the swap from 2:56 to 3:15 is no big deal, but I would have to flash my ecu & tcm so the tranny knows when to shift in Drive. And also so the speed on-meter reads correct. Can I buy a tune for that?
The swap from 2.56 to 3.15 requires changing a few things inside the differential along with the ring and pinion gears. We offer a complete 3.15 differential ready to bolt into your C6 for $1,995.00. You are correct. You will need to flash your ECM with a new file to accommodate the new rear end ratio to correct your speedo and shift points. This is something a competent local tuner will need to do. If you have HP tuners you can have a tune file emailed to you and you can flash it yourself. But purchasing HP Tuners simply for a gear change is an expensive investment for a small project. I recommend finding a local shop that is capable of doing the differential installation and the ECM calibration at the same time.
Let me know if you have any other questions. I would be happy to answer them.
Would I safely be able to do it with the diablo trinity if I purchased one that has some preprogramed tunes on it. that way I may be able to taken advantage of getting 18-20 more hp from the LS3
If your hand held programmer has the ability to adjust rear gear ratio it should work fine.
