I have seen a billion threads on C5 installs of the accusump but not much on the C6. I have a C6 Z51 vert and want to put one in next week. Anyone got pictures or some good info on there C6 accusump install (dont really want to put it in the fender and from what I have seen from a few guys here there isn't enough room like the C5)? I have a Ron Davis radiator and using the oil cooler part of it so I already lines coming out of the motor, is there anything else I need besides the accusump, manual valve, a length of tubing, and a T fitting?
Check in the General Section>>>Auto Cross/Roadracing forum. Most put the tanks in the inner fender well. You don't see it with the body back on. There is a lot of room there.
Just looked at my car at lunch, has anyone mounted an accusump to the frame rail on the drivers side next to the radiator shroud? There looks like there is tons of room but not sure it would mount straight without any twisting.
The best place that I found was the drivers side, back toward the passenger compartment. Remove the fender and the install is relatively easy. Also has the most direct routing of lines to the engine block.
I should have mentioned this at the top. The car has a Ron Davis radiator and the oil is already going thru it, so the place I was talking about has about a 1 foot run to get to the lines that are already ran. Mounting it behind the fender is gonna 5-6 feet.
I have an LGM radiator with integral oil cooler. My concern was finding the most direct path from the accusump to the engine block. The re-routing of the cooler hoses was not that difficult, some AN fittings and extra hose.
on my '07 C6, I had the 3 qt Accusump installed in the right front fender. Davenport (supporting vendor) in Calgary did the install. Works great.
Also, the battery tray needed some trimming and a smaller battery is needed. I used an Optima Red Top #35 - fits great.
I can get some pics if you would like.
Ken
Thanks Ken but I am hoping for someone to chime in on where I was hoping to put it up in front by the radiator shroud. Don't really want to hide it in the fender, I want direct access to it.
