Milling LS3 heads
Old Jan 21, 2011 | 11:36 AM
SDPC's Avatar
0SDPC
Former Vendor
Originally Posted by SpinMonster
It was well known that the 260cc runner was way too big and it was downsized in the final LS7 head. Its around 240cc's on the LS7 and that is being used on the 427 displacement.
LS7 heads are 270cc
Originally Posted by ktoonsez
Back on this topic again thinking about pulling the trigger, except no milling just porting from a local guy. Here are the flow numbers:
Flow Numbers
Intake Exhaust
.100 80.9 60.3
.200 159.9 129.9
.300 237.1 180.1
.400 291.2 226.0
.500 330.8 255.9
.600 365.9 268.1
.700 376.6 272.1
So let the comments fly..... Hope to get some good power from 4000+ RPM's
Flow numbers don't necessarily = power. Especially in a stock cubic inch engine with a smallish cam.
If you were to only do one, it should be milling (or thinner gaskets) rather than porting. The compression will help you all around but the porting will slightly hurt down low and slightly help up top. Doing both certainly won't hurt overall performance, but if you only do one it should be bumping the compression rather than porting IMO.
Old Jan 24, 2011 | 03:52 PM
ktoonsez's Avatar
ktoonsez
Thanks for the info
Old Jan 26, 2011 | 12:25 PM
C6nexttime's Avatar
C6nexttime
its been proven that most of the power comes from the mill. Its worth about 20-25 rwhp on average which just goes to show the ls3 head is to big for the motor. A good port is worth about 10 rwhp. So lets do the math. Average port job 1000 bucks. for about 35rwhp. Average mill at 100 bucks for 20-25rwhp. Which one is the better bargain? However you will kill your ptv with a mill and be stuck with smallish cams.
Old Jan 26, 2011 | 12:40 PM
ktoonsez's Avatar
ktoonsez
So is a good porting worth 10 or 35 HP?
Old Jan 26, 2011 | 12:45 PM
SpinMonster's Avatar
SpinMonster
Originally Posted by SDPC
LS7 heads are 270cc.
I stand corrected. Original info was from Chev high performance mag and I should have investigated further as there are a lot of people typing that dont do day to day installs.
Old Jan 27, 2011 | 10:48 AM
ktoonsez's Avatar
ktoonsez
Thinking about doing a head swap for Mast Black Label Med. Bore. Anybody done this swap on LS3 or similar bore/ci engine? They are saying 50-75 HP with the swap with my current setup.
Old Jan 27, 2011 | 02:43 PM
SpinMonster
As long as its a 4" or bigger bore it would work.
Old Jan 27, 2011 | 02:50 PM
ktoonsez's Avatar
ktoonsez
When you say "it would work", do you mean the 50-75 HP, or just that it will go into the car?
Old Jan 27, 2011 | 08:38 PM
ktoonsez's Avatar
ktoonsez
Bump for some Mast Black Label advice.
Old Jan 29, 2011 | 10:03 AM
ktoonsez's Avatar
ktoonsez
ttt
Old Jan 30, 2011 | 03:11 PM
ktoonsez's Avatar
ktoonsez
bump
