I know I'll need to re-index the windows, but how about the memory in the dash. You know, where you set all the various locking options and other preferences. Will I lose that and have to reset it all, or is it stored in memory somehow even if you take out the battery?
Also, will I lose the "Driver 1" and "Driver 2" memories for seat and mirror positions, mirrors, radio, etc.
You "should" be fine. The only thing you "should" have to do is the window indexing. That's not to say strange things haven't happened to a couple members' cars but that's very unusual.
Thanks . . . Stu
Just curious, what battery are you going with? I have owned my C6 new since July 2006 and I still have the original Delco battery. Thanks!
My car is about 6 months older than yours, and I'm thinking I might as well change the battery since it's only a matter of time . . . and I intend to keep the car at least 4 more years.
I'm going with an Exide battery, 5 yr warranty . . . Exide primarily because this is what my local mechanic sells. About $97.
My audio shop (friend) recommended going with the Optima Yellow Top. He said it's the best battery for the Vette in his opinion. I was going to go with an Interstate, but now I'm considering the Yellow Top.
Thanks . . . Stu
The only thing you should need to do is re-index the windows. All the other settings are retained. They do not require power to be retained, its flash memory just like your thumb drive.
Don't waste money on an Optima. They are all hype and have a very poor track record, and generally don't last as long as a regular battery. There have been several folks on this very board that have had premature failures of them. Do a simple search and you'll likely turn up at least a dozen such reports.
I had an Optima on my last car, and it didn't even last 2 years before it stopped accepting a charge. Won't ever waste money on one again.
