X Pipe Question
Old Nov 6, 2010 | 11:51 AM
VetteNGT500's Avatar
VetteNGT500
Default X Pipe Question
ok, I have an 09 base C6, soon to be e-force supercharged (554 HP kit), I'm running an SLP loudmouth II cat back, what X pipe will work? (yes, other than stock) and I'm probably not going to go with headers at this point, but may later (sorry for the incomplete question..somewhat of a rookie here) should I go with high flow cats? thoughts appreciated, thanks folks.
Old Nov 6, 2010 | 11:58 AM
FloydSummerOf68's Avatar
FloydSummerOf68
I assume you mean other than your stock X-pipe?
Do you not want to run Longtubes?
Old Nov 6, 2010 | 06:33 PM
haljensen's Avatar
haljensen
You already have a stock X pipe, why pay a couple of hundred $$ for a different one? There won't be a measurable HP/TQ gain. If/when you buy headers they will have their own X pipe so you will get to pay twice for the same thing.
Old Nov 6, 2010 | 07:08 PM
ls3gotcha's Avatar
ls3gotcha
I agree 100%
Old Nov 6, 2010 | 07:31 PM
Mike V.'s Avatar
Mike V.
Default Go all the way or leave it.
It's a bad idea to piece meal an exhaust. If your gonna change something go to headers, hi-flow cats, x-pipe. If cost is an issue, consider a complete used Z06 exhaust or leave it. I understand not wanting to do headers, but you will be leaving a lot of power on the table.
To the rest, has something changed, or is the stock crossover actually an H-pipe, if so what year did GM start doing that?
Finally, I read the articles on the Edelbrock SC & the 2 kits, it was actually on Hot Rod TV this morning. Do the hp/tq #s come from a dyno w/ headers? It has to be a bench dyno given crank hp vs rwhp.
Old Nov 6, 2010 | 08:10 PM
got2hav1's Avatar
got2hav1
2019 C6 of Year Finalist (performance mods)
I thought is was a H pipe on the factory exhaust as well. The ZR1 has an X pipe but the Z06 I know has a factory H pipe. I changed mine out to ZR1 X pipe and added Corsas. 2009 Z06 by the way.
Old Nov 6, 2010 | 08:28 PM
saplumr's Avatar
saplumr
H-pipe and x-pipe are basically the same thing.
Old Nov 6, 2010 | 09:17 PM
Mike V.'s Avatar
Mike V.
Default Not so much
H-pipes really just balance exhaust & have more effect on sound/tone than performance, X-pipes actually effect balance & flow thus performance.
To exaggerate, kinda like saying exhaust manifold & headers do the same thing, they do, but they're different.
That's why a ZR1 comes w/ an X-pipe, becuz the car design was performance 1st cost 2nd, & H-pipes are found on everything else where production cost is 1st & perf. is 2nd.
Old Nov 7, 2010 | 12:29 AM
haljensen's Avatar
haljensen
'08 and later LS3's have a factory X pipe.
Old Nov 7, 2010 | 01:53 AM
Mike V.'s Avatar
Mike V.
I can't say ur wrong, but Got2hav1 said his '09 Z06 had an H-pipe just above, which wouldn't make much sense, if X-pipes were factory on '08 base C6s. All I can say for sure my '05 had an H-pipe, I've seen C6 Z06s with them and Vipers when they came out w/ the V-10 had H-pipes as well.
Old Nov 7, 2010 | 08:03 AM
seevi's Avatar
seevi
The "H" pipe on the 2.5" and the 3" stock pipes only has a 3/4" hole on each of the exhaust pipes the "H" is connected to.
Old Nov 7, 2010 | 08:31 AM
got2hav1's Avatar
got2hav1
Definately H pipe on the 2009 Z and all other Zs I have seen.
Old Nov 7, 2010 | 09:15 AM
JoesC5's Avatar
JoesC5
I found a photo of a LS3 and it does indeed have a X pipe. Weird that GM would install a X pipe on the LS3 but retain the H pipe on the LS7.
http://www.corvettefever.com/techart.../photo_03.html
Old Nov 7, 2010 | 09:43 AM
haljensen's Avatar
haljensen
'08 and up LS3's have an X pipe, don't know about the LS7 in the Z06.
Old Nov 8, 2010 | 11:37 AM
Kenny94945's Avatar
Kenny94945
When you install the headers; install the cats.
As above, build the entire (just once) exhaust system will save you time and money.
Old Nov 9, 2010 | 09:17 AM
VetteNGT500
thanks for the advice guys, I did'nt know I already had a x pipe..and I think will probably do the entire exhaust/headers at the same time, makes too much sense, thanks for the input.
To X Pipe Question
