Rear hatch release push-switch stuck in
Old Nov 7, 2010 | 11:03 AM
Finster07's Avatar
Finster07
Default Rear hatch release push-switch stuck in
My rear hatch release switch that is just above the rear license plate does not work and seems stuck in/up. There is absolutely no movement from the switch when I push it to open the rear hatch. The switch inside the car and the hatch release on the FOB both work fine.
Has anyone had this problem and had to replace the switch? How do I remove the rear interior panel to get to this switch?
thanks
Old Nov 7, 2010 | 11:07 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
You don't. You take out the taillight next to it on the passenger side. I have seen where you can take the switch apart and clean it and get it to work. Mine is toast too from the dirt. I have one on order from Gene Culley for:
25853500 Lift gate - Gate and hardware - Release switch 2005 - 2010 1 $16.08
Elmer
I have a 2007
Old Nov 7, 2010 | 11:14 AM
SERENITY_NOW's Avatar
SERENITY_NOW
Default Easy
Do a search. Shows removal, disassembly, cleaning, reinstall. Since I had mine out I too put a new one in. Easy fix either way.
Old Nov 7, 2010 | 12:15 PM
BEZ06's Avatar
BEZ06
Hi Vic - just clean it and you'll be back in business!!
Here's talon90's great DIY info:
http://forums.corvetteforum.com/c6-c...-pictures.html
Bob
Old Nov 7, 2010 | 01:15 PM
Finster07's Avatar
Finster07
Bob
Lot's of pictures, minimal reading! Thanks Bob, I will be all over that shortly. BTW, that is an impressive avatar! And I'm glad to see you still have your DSOM Z06. Two gorgeous vettes for sure.
To Rear hatch release push-switch stuck in
