My Zero to 60 mph is 3.53 seconds
Old Nov 8, 2010 | 01:35 PM
8850's Avatar
8850
Default My Zero to 60 mph is 3.53 seconds
According to my HP Tuner log I ran a 0-60 mph in 3.532 seconds with a 1.843 60'.
Not much better than what stock Corvette can do. I have headers, intake, tune and udp. This factory torque converter is very tight. My launch rpm at 100% throttle was 1543 rpm. Peak torque of 4600 rpm came in at 30 mph. Did manage an 11.51 @ 120.3 mph 1/4 mile.
Old Nov 8, 2010 | 01:41 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Ah, I didn't know you had an underdrive pulley...did you put it on yourself? Do you know measureable gains from that alone?
Isn't 3.5 about a half second quicker to 60 than stock? I wouldn't say that's too bad while retaining the stock converter and street tires.
Old Nov 8, 2010 | 01:51 PM
LS1LT1's Avatar
LS1LT1
According to one of the online racing calculators my 0-60 is roughly 2.58 seconds but I don't believe that those are totally accurate.
8850's Avatar
8850
Can't say for sure how much the pulley added Floyd. I did dyno back when I had the Z06 manifolds without the pulley and recorded 409 rwhp. I then gutted the Z06 cats and added the pulley and dynoed 427 on the same dyno and in almost the same ambient temperature. Although the correction should compensate. So I gained 18 hp from gutted cats and UDP. If you assume each gave the same then I got 9 rwhp from the pulley.
I have high flow cats with my headers now and have not dynoed again.
Old Nov 8, 2010 | 01:53 PM
8850's Avatar
8850
Got a link. I'll calculate mine.
Old Nov 8, 2010 | 01:54 PM
FloydSummerOf68
FWIW, I ran Larry's time through what I assume is the same calculator you used and it showed his time as being a little more than 2 tenths quicker. It's close enough to get a very good idea, but not totally accurate.
That calculator showed mine at 3.2 seconds....damn your 1.5 60s
This is the link: http://home.earthlink.net/~vortmax96/Z28/0-60time.xls
Old Nov 8, 2010 | 01:55 PM
FloydSummerOf68
Thanks for the info.
And did you install it yourself? To put an UDP on is pretty labor intensive in these cars isn't it?
Old Nov 8, 2010 | 01:56 PM
LS1LT1's Avatar
LS1LT1
http://www.wallaceracing.com/0-60_equation.php
I'm curious just how far off it is from an actual HP Tuners log/scan.
Old Nov 8, 2010 | 01:58 PM
FloydSummerOf68
Ah, so you did use a different calculator.
The one you posted shows me 0-60 at 2.97 seconds, which I believe is quite generous versus the calculator I posted up showing me at 3.232.
Old Nov 8, 2010 | 02:07 PM
8850's Avatar
8850
Shows my 0-60 2.82. Not sure I believe that.
Floyd, Couldn't find the a value in your link. I did not install the pulley myself. Kurt (98Aggie) installed it for me and did the dyno. He's just outside of Victoria. Great guy to work with.
Old Nov 8, 2010 | 02:27 PM
LS1LT1's Avatar
LS1LT1
Old Nov 8, 2010 | 02:45 PM
pettvette's Avatar
pettvette
CI 5-6-7-8-9-10-11 Vet
It put my runs from this past weekend at 3.26 sec.
My 1/8 mile times... 1.88 60' 7.813 @ 92.89.... sweet!
Old Nov 8, 2010 | 02:54 PM
8850's Avatar
8850
The way my car has such a variable acceleration I don't think any of the formulas will give an accurate 0-60 bases on 1/8 mile time/speed. I launch very slowly until about 3000 rpm when the power decides to start. Somewhat like turbo acceleration. I tend to believe my HP Tuner log to be the more accurate.
Old Nov 8, 2010 | 03:02 PM
FloydSummerOf68
So what was it about my link that didn't work for you, Larry?
I can click on it and use it without any issues and it gives more accurate times (I have used it in the past with my Fbody when I had HPtuners for it to compare it to).
You should just click on the link, click open, enter your 60, 330, 1/8, 1000 and 1/4 ET and then input the new A and B value that it creates into the A and B field (the new values will be right above the graph)
Old Nov 8, 2010 | 03:24 PM
8850's Avatar
8850
2.995 seconds. Didn't look at the table long enough, duh!
Old Nov 8, 2010 | 03:32 PM
LS1LT1's Avatar
LS1LT1
Me too, though even that likely isn't exact.
Old Nov 8, 2010 | 03:34 PM
FloydSummerOf68
I still think you're doing something wrong with it. When I input the information from your timeslip you posted I get 3.282 seconds.
Your A and B numbers should be 6.3438 and 46.358.
To My Zero to 60 mph is 3.53 seconds
Old Nov 8, 2010 | 03:38 PM
8850's Avatar
8850
Your speedometer would have to be accurate and with zero tire spin for the HPT to be accurate.
Old Nov 8, 2010 | 03:39 PM
8850's Avatar
8850
They say third times a charm. You are correct, 3.282 seconds.
Old Nov 8, 2010 | 03:41 PM
FloydSummerOf68
In the end...you can safely say your car is capable of low-mid 3 second 0-60 blasts. I think that's what we can say from this thread, ha ha.
