Is the door striker adjustable?
Old Nov 9, 2010 | 05:25 PM
EVRose's Avatar
EVRose
Default Is the door striker adjustable?
The U shaped door striker on the pass. side is hitting to low inside the latch. The door still works and is aligned fine but takes more than normal pull to open and close it. You can hear it bumping before it latches. I know I will need to pull the door panel to get to it but I just need to know if the striker is adjustable up and down (mainly up) before I tear into it? Thanks.
Old Nov 9, 2010 | 08:57 PM
RicK T's Avatar
RicK T
There is a small amount of adjustment but not easy. Check this thread. Different topic but starting at post 7 might be info you can use. Good luck.
http://forums.corvetteforum.com/c6-c...ver-bumps.html
Old Nov 9, 2010 | 09:38 PM
EVRose's Avatar
EVRose
Thanks Rick. I did see that thread when I searched and didn't see any info on the striker being adjustable up or down. Mine does not rattle like the subject of that thread but I did find out how to remove the door panel. I guess I'll just take it apart and see what happens.
Old Nov 10, 2010 | 12:53 AM
haljensen's Avatar
haljensen
If the door is aligned when it's closed and latched then the striker is in the correct position. Sounds like the door hinges may be worn or sprung.
Old Nov 10, 2010 | 01:08 AM
BSSN's Avatar
BSSN
Lol, I remember my first car doing that. My grandpa wedged a 2x4 on the door, slammed it a few times while I cringed in wide-eyed horror, and guess what? The door shut with narry a bobble. Those oldsters knew a thing or two and I miss him.
That being said, I would just take it to the dealer. It can't cost that much, and it's better than screwing it up yourself. Or you could just play with it. If you can't get it, take her in. I have become a fan of dealers lately.
Old Nov 10, 2010 | 09:30 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I hope this isn't a silly question but are your windows indexed properly? Just asking.
Elmer
To Is the door striker adjustable?
