Vararam c6 install question
Old Nov 12, 2010 | 01:28 PM
Nele22's Avatar
Nele22
Default Vararam c6 install question
I just picked up a used vararam intake from a gentleman that sold his c6. I do not have the template to trim the radiator guard. Can anyone help me? This is on my ls2.
Old Nov 12, 2010 | 01:41 PM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
I can mail you one!!!! Need an address!!
Steve
Vararam Industries
Old Nov 12, 2010 | 01:49 PM
Boomer111's Avatar
Boomer111
Be real careful with trim procedure. Easy to cut into air conditioner line.
Old Nov 12, 2010 | 02:26 PM
VaraRam Industries
Supporting Vendor
Originally Posted by boomer111
be real careful with trim procedure. Easy to cut into air conditioner line.
agreed!!!!!!!
Old Nov 12, 2010 | 03:25 PM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
I believe you can also buy a shroud pre-cut
Old Nov 12, 2010 | 04:38 PM
Justasheet's Avatar
Justasheet
Steve
Vararam Industries
As I have stated before, Steve at Vararam, you have some of the best customer service of any vendor I have encountered on this forum.
Jeff
Old Nov 12, 2010 | 05:23 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Try a vibration cutter, very easy, cuts the plastic like butter and will only take you a couple minutes.
Harbor Freight sells them if you do not have one.
And +1 on Steve's customer service!
Old Nov 12, 2010 | 05:59 PM
lockman's Avatar
lockman
I just used a box cutter and took my time and put a peice of cardboard behind the shroud.
Old Nov 12, 2010 | 09:05 PM
goatts's Avatar
goatts
Take your time. Cut the hole small and keep trimming until you get the fit you want. Use a piece of thin plywood etc to protect the condenser.
To Vararam c6 install question
