2006 C-6 Rolls forward when in park..help
When I put my 2006 Corvette Coupe in park, it still rolls forward, even with the engine shut off. I have to use the parking brake. How can I fix the problem.
Hopefully your shifter needs adjusting. It may not be fully engaging the trans into park when the shifter is in park. Might be caused by sloppy shifter linkage as well. If that's not it, it's probably internal to the trans. GL
Received 2,051 Likes
St. Jude Donor '13
There is enough slop in the system that the car can roll maybe 6" before the A6 tranny stops it.
Former Vendor
