Transmission Trouble - HELP
Old Nov 15, 2010 | 03:41 PM
Thunder8's Avatar
Thunder8
Default Transmission Trouble - HELP
I'm new to the Corvette and the auto trans. Coming from a manual 6 spd to the automatic has been an adjustment to say the least. Due to a back injury, I needed to give up the manual In any case, I got my 2008 C6 coupe about 2 months ago. I just noticed that when going freeway speeds, 60-70 mph, and romp on the gas, the trans just slips like crazy and the car goes to redline and wont accelerate at all When the RPM's drop back down and after about 3 seconds, the trans will then engage again and then power to the wheels is restored. I'm pretty pissed as the GTO I had was pristine. Before I take it to the dealer, does anybody have any ideas on this? Are there known issues with this auto trans? (I've not found much relating to my issue). Is there something I should raise with the dealer, well besides the obvious? Any suggestions or advice would be really appeciated as I'm still learning about the Vette. Thanks
BTW, I bought this from a Chevrolet dealer with 16,000 miles and is completely stock back in September.
Old Nov 15, 2010 | 04:10 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Not that I know or recall anything about the A6 in the '08, but I do have a few thoughts. First, I hope you know of a very good dealership near you to take it to, should it come to that. Second, you may want to do a search on CF above, center, limit it to A6 or automatic, and further limit it to C6 Gen and Tech. Third, you don't state if it was Chev dealer bought, miles, etc.; that might help a bit. Last, when you bought the car did you do a VIS check (GM proprietary internal system to check for recalls, warranty blocks, warranty work, TSB work done, etc.)?
Hopefully, either you'll find info in CF's history of threads, or someone else with A6 knowledge will chime in. Good luck, welcome and to me, it does not sound normal at all.
Old Nov 15, 2010 | 05:14 PM
Z11409's Avatar
Z11409
2008 Chevrolet Corvette Transmission Control Module (TCM) and Powertrain Control Module (PCM) TSBs
1 TSB Number: PIP-4653B NHTSA Number: 10032434 TSB Date: September 1, 2009 Date Added to File: March 24, 2010
Failing Component:
Power Train:Automatic Transmission:Control Module (Tcm, Pcm)
Summary:
Buick/chevrolet/HUMMER/GMC/pontiac/cadillac/saturn: technicians may find DTCs P0601, P0603, P0604, P062F or P1621 stored in the tcm as an active or a history code. Some of these DTCs can also be set in the ecm or fpcm. Make sure that you
Discuss It in Forum
2 TSB Number: 08-07-30-021 NHTSA Number: 10025668 TSB Date: May 1, 2008 Date Added to File: August 28, 2008
Failing Component:
Summary:
Loss of high speed gmlan communications, intermittent no crank, ipc gauge fluctuation, intermittent door lock cycling, transmission may not shift, DTCs U0073, U0100, U0101, U0102, U0121, U0140 set (repair backed out terminal in transmission
Discuss It in Forum
3 TSB Number: 08-07-30-021 NHTSA Number: 10025402 TSB Date: April 1, 2008 Date Added to File: August 6, 2008
Failing Component:
Summary:
Loss of high speed gmlan communications, intermittent no crank, ipc gauge fluctuation, intermittent door lock cycling, transmission may not shift, DTCs U0073, U0100, U0101, U0102, 70140 (repair backed out terminal in transmission harness co
Old Nov 15, 2010 | 05:20 PM
Thunder8's Avatar
Thunder8
A HUGE Thank You to Z11409! I believe that's exactly what I need! That's just perfect!!!
To Transmission Trouble - HELP
