I have a 2006 ls2 with , long tube headers and corsa cat back , air ride intake ,and i tunne it at a dyno and make 384hp at the wheels what u guys thing about that i shoul make more then that ??????
What was your baseline on that dyno? Dont worry so much about the final number, the difference between your baseline and your final number is the important one.
on my cobras, one of the first things i would do is gears, although it did nothing in th rwhp area, it def added alot of low end power, since it brings th powercurve lower and you have instant power. This will def. knock a few ticks off you 1/4 mile
my base line was 358 at the wheel and at the end the most was 384hp but people has tell me with the same things i have they had done 410 hp at the wheel u think thas true
The gain does seem a little low. Was the baseline done on the same dyno as the final tune? Were the conditions similar? Does your car run good or is there something in how it is running that is making you question your power numbers? Even on the same dyno the numbers will move around allot due to changing conditions.
Those dyno numbers are just about right for your mods. I had my Z51 LS2 dynoed after Jeremy Formato tuned it and at that time had the same numbers but the D/A was abysmal at the time--about what you'd have in Florida, so those numbers seem about right.
thanx for the opinions guys .but wow so let said that the dyno numbers are not correct I have less than that wow i, what u guys think if i do heads and cams do i make it to 450 whp ?
