Cutting lowering bolts
Old Nov 23, 2010 | 12:10 AM
t.borries's Avatar
t.borries
Default Cutting lowering bolts
What do you use to cut the donuts off of the lowering bolts?
Old Nov 23, 2010 | 09:41 AM
mittens's Avatar
mittens
hack saw.
Old Nov 23, 2010 | 09:45 AM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I used a sawzall and a hand type hacksaw.
Old Nov 23, 2010 | 09:17 PM
Mike V.'s Avatar
Mike V.
Default Same
It's just tuff to get in there but it can be done w/ a little patience. But removing them is a considerble amount of work, so it's worth the frustration vs taking everything apart.
Old Nov 24, 2010 | 10:35 AM
Neumonic2002
So true, unbolt the bottom of the shock and push them up out of the way for some extra room when working on that bolt, makes all the difference.
Old Dec 15, 2010 | 05:33 PM
kuba's Avatar
kuba
Actually guys can someone tell me how to lower my c6 z51 , step by step
Old Dec 15, 2010 | 05:36 PM
kuba's Avatar
kuba
hey so how do u lower it step by step
Old Dec 15, 2010 | 06:41 PM
AYello1's Avatar
AYello1
The quickest & simplest way to lower the car is to let all the air out of the tires. If you want it even lower, remove the wheels and run on the brake rotors. Of course both of these methods do have some drawbacks....but they are quick & easy.
Just doin' my part to help a brother out!
Old Dec 15, 2010 | 06:50 PM
MikeSVT04's Avatar
MikeSVT04
http://www.vetteweb.com/tech/vemp_07...ing/index.html
If you don't want to go real low there is no need to cut the bushing...
I'm going to lower mine in the spring, but im not ganna take my suspension apart. I'm just ganna get in there and hack them off.
Old Dec 15, 2010 | 06:51 PM
Jon@Texas-Speed's Avatar
0Jon@Texas-Speed
Former Vendor
I tried to cut mine the first time I did it and it was a huge pain in the rear. Well worth the money to go out and buy the lowering bolts and just swap them out.
Jon
Old Dec 15, 2010 | 06:57 PM
MikeSVT04's Avatar
MikeSVT04
^ how so? I was under the car the other day and it looked kinda easy...tight but doable..
are the bushings hard as rock or something?
what about a blow torch and melt them a bit to make them easier? hahaha idk im just thinking out loud.
Old Dec 15, 2010 | 07:00 PM
kuba's Avatar
kuba
oh, ok i did that and now what?
Old Dec 15, 2010 | 07:03 PM
MikeSVT04's Avatar
MikeSVT04
what did you just do? its kinda straight forward man.
Old Dec 15, 2010 | 07:18 PM
kuba's Avatar
kuba
awesome thanx man
Old Dec 16, 2010 | 01:00 AM
smurfkiller's Avatar
smurfkiller
sawz-all is god. if you dont have one then why the hell not buy one. it can be done without removing the bolts but alot easier if you do. i removed my rears cut off the bushing with sawz-all and replaced with 1/4'' bushings takes less than a hour to remove and reinstall them.
To Cutting lowering bolts
