Double hinged gas pedal fix?
Old Nov 28, 2010 | 05:19 PM
BoosterClub's Avatar
BoosterClub
Default Double hinged gas pedal fix?
I find the double hinged gas pedal in the corvette extremely annoying, the fact that the pedal can move and no throttle change occurs drives me nuts. Besides just ziptieing it so that one of the hinges doesnt move anymore is there any other fix for this thing?
Old Nov 28, 2010 | 05:38 PM
Bill Dearborn's Avatar
Bill Dearborn
You do know that the gas pedal isn't mechanically connected to the throttle? There are accelerator pedal sensors in the gas pedal assembly that send signals to the PCM and TAC modules that electrically control the position of the throttle. These modules determine how much to move the throttle not the driver.
Bill
Old Nov 28, 2010 | 05:54 PM
BoosterClub
Bill
Whether its cable driven or DBW doesn't matter, you push the throttle pedal the throttle should move.
This is irregardless if the double hinge is preventing a throttle cable from being pulled or preventing a variable resistor from showing a change, doesnt matter.
I don't think you realize what I'm talking about, if you do then your posts was totally unrelated to anything that I said. What I'm talking about is when you push the throttle the plastic front of it can pivot and the actual throttle pedal arm stays stationary.
Double hinged throttles belong in grandma passenger cars.
Old Nov 29, 2010 | 07:26 PM
BoosterClub
I ziptied it today to see if it made a difference like I thought it would and it made a huge one. Does this not bother anyone else or something? I could barely drive the car because I thought I was giving it gas because the pedal was moving but wasn't.
Old Nov 29, 2010 | 07:28 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Geee, I never noticed it!!
Old Nov 29, 2010 | 08:06 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Same here.
68k miles in C6's and it just seems like a gas pedal to me.
Is OP driving barefoot?
BTW, Bill Dearborn has been on this Forum a long time and has helped a lot of people.
His comments may not have helped you this time, but dissing him won't make you any friends.
Old Nov 29, 2010 | 08:30 PM
VET4LES's Avatar
VET4LES
27,000 miles and I've never noticed anything different from my other auto's.
Old Nov 29, 2010 | 08:40 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I remember the old gas pedals hinged from the bottom, didn't they do away with those for safety reasons? Maybe they did it so women could drive in high heels.
Actually, I think the Vette's gas pedal is on the plane where it is so that you can heel and toe for downshifting. I know my Vette is a lot better than my Trans Am was for that purpose. I just checked, and if the Vette's wasn't double hinged, you wouldn't be able to get WOT - the pedal pushes in at the top through the extra spring pressure for the final 20% of its travel. Kind of like my old Quadrajet, you could tell you were getting into the 4 barrels when the pressure on the pedal got stiffer.
When yours is zip tied up (I'm assuming you zip tied it at the top so the bottom of the pedal is higher than it normally is) can you still do heel and toe downshifts? I would think your foot would hit the side of the pedal.
I guess if you don't heel and toe, what do you care!
Old Nov 29, 2010 | 08:58 PM
VET4LES's Avatar
VET4LES
My guess is it's double hinged for drivers comfort. Every drivers foot rest on the pedal at a little different angel and the double hinge works for everyone except one forum member.
Old Nov 29, 2010 | 09:19 PM
BoosterClub
Dissing him? If you consider clarifying "dissing" then I don't know what to tell you. Either he didn't understand or he just felt like posting something irrelevant to the question I was asking. I don't see how that's "dissing".
Wouldn't matter on an Auto, you don't need precise control to start off in first or rev match downshifts in an auto.
My BMWs are hinged this way, part of why the vette was throwing me off so much since I'm used to this. If you press the vette pedal the way you do the BMW pedal you get no throttle, which makes any performance shifting hard.
Yes from the top, it made heel toeing easier, since I don't heel and toe, I ball and side of foot .
Its definitely for comfort. I really can't believe this doesn't bother anyone else on this forum, I know it bothers some people I know, but cute comment.
Old Nov 29, 2010 | 10:30 PM
Streetk14's Avatar
Streetk14
I've owned almost nothing but BMWs as my regular cars, so I can see what you mean. Any pedal movement= throttle change. Even though I drive my E46 every day, the C6 pedal doesn't bother me for some reason. Its very similar to the Lokar gas pedal I had in my '67. If you push on it a certain way, you really aren't doing anything. I don't think its bad, just different.
Old Nov 29, 2010 | 11:30 PM
m R g S r's Avatar
m R g S r
doesnt bother me and im used to my honda s2000 gas pedal which was super responsive...
Old Nov 30, 2010 | 04:31 AM
nowheelie's Avatar
nowheelie
Booster - I think I understand what you're saying. I could see depending on how you "rest" on it, or how you place your heel that it might have a dead feel, or wobbly/laggy feel.
I haven't perceived any of the above problems though, but I am curious to mess with the pivot a bit so it's less active, see if it makes any dfference to me or not.
why not, just something to tinker with in terms of customizaion.
Old Nov 30, 2010 | 08:58 AM
BoosterClub
Try putting a couple heavy duty zipties across the top tying the top of the pedal against the arm. That would immobilize it just to give you an idea, definitely not a permanent thing though.
Old Nov 30, 2010 | 09:02 AM
FloydSummerOf68's Avatar
FloydSummerOf68
I know what you mean, but my foot always rests in an even position on the pedal, so I never really get any of the hinge motion. If I drive barefoot it bothers me a bit...but that doesn't happen often.
Old Nov 30, 2010 | 09:44 AM
BoosterClub
I'm used to planting my heel on the floor and pushing my toes forward to give throttle, do you slide your heel on the floor?
Old Nov 30, 2010 | 09:49 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
I wonder if that is why I've been having trouble driving my Z. I've only had it a few days and the first thing I noticed was that the throttle seems very numb in the first 5-10% or so of travel - right where one would need to be for smooth street launching and shifting. My 90 is very responsive on the low side of the travel so this is a bit strange to get used to. I might have to just pay more attention to where my foot is next time I take her out.
To Double hinged gas pedal fix?
Old Nov 30, 2010 | 11:56 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Actually, if you have an 05, your car is tuned from the factory to be sluggish (your Z is not tuned to be sluggish, IIRC, I checked and it's all 100's in this table) - the accelerator pedal has a slow ramp rate from the movement of the pedal to the movement of throttle blade. I complained about this for years after I went from my 02 to my 05 - heel and toe was harder in the 05 as it had sluggish throttle response. Back in 2009 HP Tuners finally came out with a beta that allows you to adjust the ramp rate of the throttle.
Here are a lot of details on that for those interested. It was a great change for my 05.
http://www.hptuners.com/forum/showthread.php?t=21714
I think the factory stopped making the Vette throttles lazy with the later years. As I recall 08's and up were set for aggressive ramp rates.
But if you've got an 05 then a tune will do wonders for your throttle response, but you have to be sure to tell the tuner to get the beta from HP Tuners and adjust this table. EFI live has this table as well but it might not be part of a "normal" tune so you have to mention it to your tuner.
Old Nov 30, 2010 | 02:48 PM
Bill Dearborn
No, I did not know what you were talking about and probably still don't. I have never had that issue. When I lay into the throttle I get the response I am expecting. I have no issues with performance shifting if you mean heel and toe downshifting and I do a lot of heel and toe downshifting. As for comparing to a BMW I have only driven a few students M3s at about 70%. Never noticed anything special about their throttle except there wasn't enough power.
Bill
Old Nov 30, 2010 | 03:35 PM
BoosterClub
Bill
Read through the thread, it should be quite clear by now exactly what I have been referring to, without repeating what I already have. "laying into" the throttle isn't the problem, its small throttle input from 0 throttle.
