Oil/fluid leak - help!
Old Nov 29, 2010 | 08:39 PM
jjtrokejr2005's Avatar
jjtrokejr2005
6th Gear
Default Oil/fluid leak - help!
Fluid on my garage floor. May be engine oil or power steering fluid- can't tell for sure. But, I can't find a source! Any suggestions?
Old Nov 29, 2010 | 08:57 PM
RicK T's Avatar
RicK T
Well, identifying it is the first concern. Maybe put some newspaper or cardboard under it for a night to try to pinpoint where it's actually dripping from.
Old Nov 29, 2010 | 09:29 PM
B y r o n's Avatar
B y r o n
Power steering fluid and engine oil are totally different. Look for color and smell and feel. Power steering fluid is thin and a lot of times red. Oil changes depending on new or old but is generally thicker. Time to crawl under, after it's on a jack and look around. Can't help more based on the limited info.
Old Nov 29, 2010 | 10:46 PM
Timothy Barth's Avatar
Timothy Barth
It is hard to tell from what you describe,but it could also be the water pump leaking.
Old Nov 30, 2010 | 08:46 AM
jjtrokejr2005
6th Gear
Thanks for all the input. I did put tissue paper under the area where the fluid showed up previously last night. Checked it out this morning, and not a drop! Based upon where the fluid was on the floor versus my memory of where it was parked night before last, it was under the rear of the engine. Probably not engine oil, as it wasn't dark enough, but too far from the front of the car to be power steering fluid. Any chance it could be tranny fluid? If so, from where might it leak?
Old Nov 30, 2010 | 01:11 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Tranny is in the back on a C6, so that should be out.
Old Nov 30, 2010 | 08:11 PM
jjtrokejr2005
6th Gear
Okay, I think I've pretty much confirmed that it is power steering fluid. Any suggestions about what to check as the specific source? I haven't been back under tonight, as don't have the time, but when I do, what should I check for? Is there any common issue I should be looking for?
Old Nov 30, 2010 | 08:32 PM
Paratrooper307's Avatar
Paratrooper307
If your car has a transmission cooler, check the lines. ATF is generally red, could be you have a loose or damaged line. All autos and z51/z06 manuals have trans cooler lines.
To Oil/fluid leak - help!
