TPS for track wheels
Any advice appreciated.
Thanks,
Gary
if they are not compatible and have to be banded onto the inside of the wheel, then i would just skip them.
Gary
http://forums.corvetteforum.com/c6-t...rol-ussue.html
That 30/60 minutes is without shutting the ignition off. If you're driving along in Comp mode or with AH off when you get that message, the AH will automatically come back full on. However, you can stop the car, shut it down, restart, clear any messages, and you'll have another 30/60 minutes where you'll be able to run in Comp or with AH off until you get that message again.
Most guys that track the car don't want to have problems toward the end of a session by having the AH come back on if they're running in Comp or with AH off. Not only does the AH come back on, but it thinks you may have a tire problem, so it tries to protect you. When AH detects that you are driving aggressively with a possible tire problem, it will put on individual brakes when you start turn-in, and you'll have power pulled on you when you try to accelerate out of a corner - and you may have somebody behind you all up in your tail end!!!
Plus, it's very nice to know on the track if you're losing pressure half way through a session. With sensors, you can pull into the pits instead of continuing to drive hard until you end up in a tire wall.
I run sensors in my track wheels/tires.
Bob
