Old Feb 23, 2015, 02:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Best cold air intake...
Old Dec 4, 2010 | 08:47 AM
5knives's Avatar
5knives
Originally Posted by OBSSSD@work
Vararam is garbage buy it if you like ghetto rigging with duct tape and cleaning your filter every 1500 miles
It's funny because I've read a lot of comments like this but then also read that the performance is great and the issues people complain about aren't as bad as they're made out to be.
Has anyone swapped in an LS3/7 air intake to an LS2? From what I read the LS3/7 air intakes are nowhere near as restrictive as the LS2 and could offer similar performance as an aftermarket unit. That combined with a propped/cut shroud may be a good idea and could probably be had for cheaper than even a used aftermarket CAI.
Old Dec 4, 2010 | 11:43 PM
LS1LT1's Avatar
LS1LT1
Quite interesting considering I have NO duct tape, glue or extra screws on my (older, first generation) C6 Vararam after almost 4 years of use/abuse.
And cleaning the air filter more often? Hmm, let's see, more dirt/dust finding it's way on to one's air filter, what could that possibly mean?
Maybe that the intake/filter (and subsequently, THE MOTOR) are also receiving more cold air?!
It is quite ironic isn't it?
Old Dec 5, 2010 | 12:22 AM
S'vette's Avatar
S'vette
I know with my last car, when people were buying so called CAIs which were actually filters on a stick, even tho they might be placed in a different location, were seeing some gains in HP. Now we found out that the gains were actually from the new intake having a slightly larger MAF section which caused the car to run a little leaner which account for the gains and not really it being a so called CAI.
Now are these after market intakes for the vettes doing the same thing or is the MAF section the same size?
Also our stock intakes pull air in from the outside right? I havent really examined it yet as Im still zooming away with the new car.
Old Dec 5, 2010 | 12:08 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I would agree with you, I had to get a tune for my cai to actually work properly (when the engine goes lean with stock tune it just dumps fuel to compensate when @ WOT)
So aftermarket intakes will make more power on an LS2, the factory intake is not very good (both air intake and intake manifold) but you still have to tune any system you end up purchasing.
Now unless you are getting a system that can pull air from outside the engine compartment your just getting a really expensive air filter and tube IMO that will increase power with a tune as it has the ability to pull in more air than the stock setup due to a larger and better air filter but a true cai is the only thing I would spend any money on.
Old Dec 5, 2010 | 12:17 PM
S'vette's Avatar
S'vette
Isnt the stock intake a true CAI? Again I havent been under the car to see if the intake, that looks to be a closed intake, is getting its air from outside the engine. What Im wondering is how much air is a stock vette asking for at WOT? And does the stock intake allow it to get that much air? In my last two cars I just put in a good high flow filter as the intakes were IMO CAIs to begin with. An intake that has a slightly larger MAF section will gain some power but by going lean and Ive heard of some cel faults on cars that did intake and full exhaust and ran too lean and got cels.
Old Dec 5, 2010 | 12:29 PM
teuhl's Avatar
teuhl
Go with a Callaway Honker, Dyno Tune and low temp thermostat. If you want a little more Hp, add headers and hi-flow cats.
Old Dec 5, 2010 | 02:51 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
No.....you can cut the under hood heat off with something like a Beehive, but stock will suck hot air if given a chance, especially at the starting line.
Larry
Old Dec 5, 2010 | 06:36 PM
S'vette's Avatar
S'vette
Larry
where is the stock intake gettings its air from? Outside air being rammed in from the front area or inside the engine? Cuz the intake goes all the way to the front and looks like its getting the air from the front being rammed in. I guess I need to take a good close look. Is there a scoop that directs the air to the intake?
Old Dec 5, 2010 | 07:15 PM
JoesC5's Avatar
JoesC5
On a base C6 there are small openings to the grille just below the impact crash sensors that pull in outside air, and then large openings next to the frame rails that get outside air from under the car in the high pressure zone in front of the air dam. On the Z06, ZR1 and GS the opening at the top front bumper lets outside air into the air breather compartment to supplement the other air openings. There is no direct air being force fed to the air breather. It gets it's air at the bottom of the compartment that has a shroud to isolate the air breather from the radiator/engine.
Old Dec 6, 2010 | 09:22 AM
studiovette's Avatar
studiovette
I think we all have established that the LS2 lacks a good intake/ breathing system, and getting some outside air directly fed to the stock filter assembly or an aftermarket unit of your choice will be a big healthy improvement for the engine and HP gain. With that said you can remove the stock air intake in 5 minutes cut the shroud install a vette air and any aftermarket or your stock intake and go from there. This can all be done cheaply and quickly, also keep in mind a new shroud cost 45$ to replace if you ever wanted to go back to stock. I did mine last week in about 2-3 hrs only cause I replaced my shroud with a precut one. If I did it all over again I would cut it right on the car! SO much easier! The shroud is a PITA to remove and then put back in again.
I'm more curious now as to some of the convo I have been hearing about swapping to the Z06 air intake on a LS2 is this doable? And what else would I have to change or watch out for?
Old Dec 6, 2010 | 05:41 PM
SpecialSause's Avatar
SpecialSause
Originally Posted by TommyV
The Vararam has a ram air effect where the other two are just cold air. You might want to consider a 160 degree t-stat and a tune. The LS2 starts to pull timing when the coolant gets above 212 degrees.
I'd get a 180 degree thermostat instead of the 160 imo
Old Dec 7, 2010 | 10:04 AM
studiovette
why 180? Isn't the stock t-stat a 186 ? Do you even notice a difference in running temp? Just curious cause most go with the 160 even some of the best tuners recommend that.
Old Dec 7, 2010 | 12:30 PM
  #33
5knives's Avatar
5knives
Depends on when and where you're driving the car. If you see below freezing temps during the winter months, and drive your C6 often during that season, it may take longer for the engine to come up to operating temperature. This is especially an issue if you're only taking short trips with the car. For those that live in warmer climates it's not an issue. I even know people who swap out 160/180/stock t-stats depending on the season.
Old Dec 10, 2010 | 07:35 PM
  #34
BowTieBlood's Avatar
BowTieBlood
I installed the LPE CAI about a year ago and have had no issues with it. The fit and quality are top notch; no cheap pieces to be found. Good luck
Old Dec 12, 2010 | 10:41 AM
  #35
OBSSSD's Avatar
OBSSSD
I've had two of them and the build quality was not even average on either of them. They have to repositioned on a regular basis and don't fit for %^&#! As far as the "cold air" if you log your actual temps while driving there isn't much difference between the two different setups once you are moving. If you don't mind cleaning your filter 3-5 times a year and jacking with the system from time to time, and maybe having to use tape to hold it then please by all means buy the Vararam.
I'd rather not screw with my car all the time but to each his own
Old Dec 12, 2010 | 03:49 PM
  #36
LS1LT1's Avatar
LS1LT1
Once again, what the heck does a dirty air filter have to do with anything?
Is buying a performance part more about looking good at the local car show or is it about doing the job that it's designed to do?
More outside (and colder) air hitting a panel is going to generate a little more dirt/dust, yes.
I'm surprised more people aren't seeing that, it's very simple logic actually.
Old Dec 12, 2010 | 06:44 PM
  #37
goatts's Avatar
goatts
Have you ever had one?
To Best cold air intake...
Old Dec 12, 2010 | 06:46 PM
  #38
goatts's Avatar
goatts
You'll find that 99% of the guys that make these comments have never had one on their car and probably have never even seen one so they're just talking out their butt.
Old Dec 12, 2010 | 06:54 PM
  #39
FUNTRUN's Avatar
FUNTRUN
Vararam. With the 1/4 mile times and speeds to back it up.
Old Dec 12, 2010 | 08:24 PM
  #40
2010 Silver GS's Avatar
2010 Silver GS
Cruising
Yeah, I think I'm going to go with VaraRam. Would like to try the Volant Ram Air but I can't find any reviews. VaraRam seems to be the proven leader.
