Oil Cooler Recommendation Needed
Thanks in advance for the help and info
Hawk 6
Thanks again
Hawk 6
Here is what I have experienced:
- Install was not too bad, I could do the next one in 2 hrs or so now that I know where to run the lines, cut the shroud and place the clips. Let's just say the first time took me an afternoon.
- Normal driving was at 220 to 230, now runs between 185 & 195. I do not have an issue with long warm up in 55 degree temps (live in S Cal).
- Spirited on Street (local canyons) was at 245 to 255, now runs 205 to 210.
- Track Day (@ Streets of Willow) was at 280 to 300, today I saw a high of 250 at the end of a session w/air temp at 55 degree's. Was at 235 ish after cool down lap and back in pits.
So far seems to be meeting my expectations which were to drop track day temps to below 275.
Feel free to PM with any questions regarding install.
I am now looking to install a PS Cooler as I seem to be boiling my fluid at track days.
Ed
Thanks for any responses.
Sean
Edit: looks like this thread started with the Z51 integrated radiator/oil cooler in mind. Never mind. Anybody know where I can get a complete kit used?
Ron Davis radiators provide 20% better cooling over the oem radiator, that combined with the integrated oil cooler should do the job as well
I think you need a pre 2008 or 2009 Z06 cooler. I also have a Z51 and when I upgraded to a Z07 radiator, I got a Z06 cooler from Breathless that they took off a car complete with oil line.
Can these parts be purchased separately from Gene or other vendor? No part numbers listed for the retaining clips or connectors...
