My car ran hot but never overheated. I want to know how to clear the amber colored horseshoe with exclamation point in the middle on the instrument panel. How do I get rid of the symbol. Thanks Nobody knows how to clear this warning light off my dash panel ???
The horseshoe with the exclamation point is the tire pressure monitor. If it's on, that normally means one of your tires in underinflated.
If the tires are okay, disconnect the battery for 5 minutes. That should clear the indicator, but if there is a problem with a tire presuure sensor, the light will most likely come back.
