Assembly sequence for shock hardware
Old Dec 11, 2010 | 11:52 PM
vetracer's Avatar
vetracer
Default Assembly sequence for shock hardware
How do these parts go together on top of the front and rear shocks?
Not even sure if I have the correct parts shown, this is what I purchased from another member to put my C6 Z back to stock.
Any help would be appreciated
Old Dec 12, 2010 | 03:01 PM
vetracer's Avatar
vetracer
Anyone??
Old Dec 13, 2010 | 05:55 PM
thirtythird's Avatar
thirtythird
I kept my original rubber grommets and parts when I switched to Bilsteins. The stuff those shocks came with were very generic looking. If you remove your shocks and take your time it should be obvious. Did you use your original rubber parts when they were switched originally?
The piece that has the long shaft goes on the front shocks. It goes up from the bottom, through the opening.
There was a really good do-it yourself thread about the shocks. Let me see if I can find it.
Old Dec 13, 2010 | 06:10 PM
thirtythird
http://forums.corvetteforum.com/c6-c...-reviewed.html
Not exactly the thread I used but it gives you an idea of how the parts go. He has them laid out in order.
To Assembly sequence for shock hardware
