Caliper Bolt Spec
Old Dec 17, 2010 | 04:15 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
Default Caliper Bolt Spec
I broke the top bolt that bolts the caliper to the bracket.
does anyone know what size, type bolt it is so i can goto ace and grab another one? or is this only available from GM?
-Carl
Old Dec 17, 2010 | 06:16 PM
RicK T's Avatar
RicK T
Info in here might help (I have no personal knowledge, sorry):
http://forums.corvetteforum.com/c6-c...bolt-part.html
Old Dec 17, 2010 | 06:29 PM
1SwtRide's Avatar
1SwtRide
No. 4 is it and don't forget the red loctite
Old Dec 17, 2010 | 06:31 PM
carlrx7's Avatar
carlrx7
Thanks!!
Originally Posted by BEZ06
If the part you're looking for is the "caliper bolt", which is item# 4 in the picture above, it's GM Part# 14084015 and it's about $6.65 list price, and around $4.50 from a forum vendor.
If you're looking for the "caliper guide pin", then it's item# 6 in the picture, GM Part# 88955515 and costs about $43 list, about $33 vendor discount price.
Good luck, and double check those part#s before you order!!!
Bob
#4 is what i broke. think i might just order the #4 and #6 since peices of the #4 bolt is stuck in the #6
-carl
Old Dec 17, 2010 | 06:36 PM
carlrx7's Avatar
carlrx7
and i would like to add this post as well.
Originally Posted by BSE1956
BEZ06 has the right diagram. The bolt is an 8mm - 1.25 pitch - 20mm length. IF you buy one, make sure it's a 10.9 hardness and rust resistant.
Old Dec 19, 2010 | 03:19 PM
carlrx7's Avatar
carlrx7
can't find anyone who carries p/n 14084015 , found some M8 1.25 10.9 bolts at advance auto, but they looked slightly different, gonna check ace tomorrow.
To Caliper Bolt Spec
