C6 Battery Replacement
Old Dec 18, 2010 | 08:05 PM
prplprl1's Avatar
prplprl1
8th Gear
Default C6 Battery Replacement
I know this question has been answered before, but I can't find it. Is there anything special about changing the C6 battery (2007 Z51 Coupe)? I seem to remember warnings, but can't find them. Your help, please.
Old Dec 18, 2010 | 08:38 PM
timd38's Avatar
timd38
You have to index the windows. Directions are in the owners manual.
Old Dec 18, 2010 | 08:43 PM
RicK T's Avatar
RicK T
No.....only make sure you get the correct terminal orientation and you will have to re-index the windows when done.
If you go to bugmanweb dot com, in the yellow index pane on the left side click on Battery-Optima. There you will find excellent info including an install guide.
Have fun.
Old Dec 18, 2010 | 09:01 PM
goatts's Avatar
goatts
Swap it out just like any other battery.
Old Dec 19, 2010 | 07:36 AM
prplprl1's Avatar
prplprl1
8th Gear
Thanx,, guys for your help. I found the indexing info in my manual, and also found that I have purchased a battery with the polarity, backwards. I am resolving that today, and hope to have no further trouble.
I also appreciate the input that I can rotate the battery and install it backwards--that's a big help in case I have trouble getting the correct one. Thanx again, guys.
Isn't this forum great?
Old Dec 19, 2010 | 11:56 AM
j_digi454's Avatar
j_digi454
Originally Posted by prplprl1
Thanx again, guys.
Old Dec 20, 2010 | 12:37 PM
prplprl1's Avatar
prplprl1
8th Gear
Default C6 Battery replacement
I replaced my battery with a new Optima (terminals are correct). I get some internal lights and dorr open dinger, but when I push the start button, all goes dead. Any ideas?
Old Dec 20, 2010 | 12:39 PM
timd38's Avatar
timd38
I don't know were you got the battery, but if sat for a long time it may need a charge.
I would start there.
prplprl1's Avatar
prplprl1
8th Gear
Have fun.
Internal lights come on, but when start button is pushed, it all goes dead.
Old Dec 20, 2010 | 12:42 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Just remove the negative terminal first and install it last. This is to eliminate any risk of the wrench touching a ground if you try to remove the positive first or install it last.
I had a battery explode big time once because I grounded the positive terminal with a wrench. Acid flew everywhere. Apparently, a spark ignited hydrogen inside the battery.
Old Dec 20, 2010 | 01:25 PM
CraigE's Avatar
CraigE
The polarity is reversed, or the terminals are reversed ?
Old Dec 20, 2010 | 04:08 PM
prplprl1's Avatar
prplprl1
8th Gear
No, I checked that.
Old Dec 20, 2010 | 04:17 PM
timd38's Avatar
timd38
There is a huge + and - on the top of the battery, how can you put it on backwards. Plus the posts are different sizes, you have to force one on and the other would be loose.
Old Dec 20, 2010 | 06:39 PM
saplumr's Avatar
saplumr
Nothing like "energizing" the frame.
Old Dec 21, 2010 | 08:26 AM
prplprl1's Avatar
prplprl1
8th Gear
I finally gave up and took it to the Corvette dealer. The service manager jammed it into "Park," and it started up just fine. The shifter was broken, anyway, so no added harm done. Thanks to all who tried to help. Merry Christmas.
To C6 Battery Replacement
