I have developed a noise that gets louder the faster I go. It sounds like tire noise. I just had 4 wheel alignment done and notice it after. It started with little roar and has become worse last couple of days. The shop can't get it in until later this week.
Could be several things. Tires, ring and pinion, brearings. A shop that knows what they are doing will go through a series of steps to determine the cause. One thing to check before you start is see if the alignment shop kept the tires in the original location (left to right), particularly if they are directional tires. It is interesting that the noise got louder after the alignment.
