Oil consumption issue
Old Dec 20, 2010 | 05:53 PM
shifter77's Avatar
shifter77
Default Oil consumption issue
My 07 Z with 39000 mls has been consuming lots of oil. Ive had to add 1 quart of oil several different times only after spirited/high rev driving.
I would say approx after 80-90 mls of high rev driving. Engine & oil pressure are fine.
P.S. Backend & pipes completely black.
Seggestions please.
Old Dec 20, 2010 | 06:13 PM
TARANTULA's Avatar
TARANTULA
Seggestions please.
Did you check inside the intake for oil?
Old Dec 20, 2010 | 07:46 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Seggestions please.
my pipes get black pretty quick as well....
Old Dec 20, 2010 | 07:55 PM
shifter77's Avatar
shifter77
Yes, i did find oil on the intake & cleaned it out. Will check again.
If sensor has oil again. What then??
Old Dec 20, 2010 | 08:07 PM
goatts's Avatar
goatts
Did you buy it new? If you burn a quart every time you run it hard then your rings may be shot.
Old Dec 20, 2010 | 08:28 PM
shifter77's Avatar
shifter77
Yes, bought new in07.
Old Dec 20, 2010 | 08:31 PM
TARANTULA's Avatar
TARANTULA
Take the intake off, open the throtle body and with a flashlight look inside and see what you find. This could tell you were the oil is coming from but not why is getting there.
Old Dec 21, 2010 | 01:22 PM
Kenny94945's Avatar
Kenny94945
Do a compression AND leak down test.
Rule out a problem.
Old Dec 21, 2010 | 01:37 PM
AirBusPilot's Avatar
AirBusPilot
Did you use the "drive it like you stole it" break in procedure? Or something more careful?
Old Dec 21, 2010 | 06:33 PM
shifter77's Avatar
shifter77
I had spoke to my Gm service advizor about a leakdown test with no results the 1st time brought car in for this issue. The tech told me he changed the 16 rubber seals top of engine. Not shure what that means.
He also mentioned that he was not shure that the seals will solve the oil issue.
Old Dec 21, 2010 | 06:48 PM
VET4LES's Avatar
VET4LES
The sixteen seals are valve stem seals. They can cause oil consumption. If that doesn't cure the problem then a leak down test is necessary.
Old Dec 22, 2010 | 08:50 AM
shifter77's Avatar
shifter77
Thank you fellow members for your input & Happy Holidays.
Got appt. with GM in Jan. 2011. Figured it would be best to address oil issue after all holidays are over.
GOD SPEED.
Old Dec 22, 2010 | 09:39 AM
da vette guy's Avatar
da vette guy
usually valve stem seals will smoke at idle or after hot restart, and first accel ,ring problems will smoke generally worse on heavy acceleration and high rpm. the catalytic converters can hide a lot of oil consumption smoke.
Old Dec 22, 2010 | 01:32 PM
goatts's Avatar
goatts
What do you mean by high rev driving? How high, how long, how often? What rpm do you cruise around town at?
Old Dec 22, 2010 | 02:07 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
GOD SPEED.
I sent you a little info in a PM regarding the oil consumption issue and what GM will likely do.
Old Dec 22, 2010 | 02:28 PM
da vette guy
sometimes this happens before you buy it,like when it's prepped at the dealership or maybe on a test drive
Old Dec 22, 2010 | 03:26 PM
sallen619's Avatar
sallen619
Seggestions please.
Mine drinks oil like that when I drive it hard....A dyno tune got rid of the black pipes.
Old Dec 22, 2010 | 03:34 PM
shifter77's Avatar
shifter77
Ive had my Z brand new and broke her in real smooth. Cant complain. My car has 39000 + hard driven miles. By high rev I mean 6200-6700 RPM in every shift 1-5. I can see and feel sticky residue on my Z rearend. Service took note of it. Ill get it all squared away in JAN .
Thanks again fellas.
Old Dec 22, 2010 | 04:26 PM
Xwet's Avatar
Xwet
I found a lose intake manafold on 1985 vette. I used a quart every 800 miles. Showed no smoke at the exhaust but pipes were shiney black.
To Oil consumption issue
