frame rail
Old Dec 30, 2010 | 12:40 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Default frame rail
in the frame rail that is under the front bumper there is a piece of metal shaped like an accordian, what is it? what is it's purpose? can it be safely removed? and how?
im installing a tow hook that i made and need to beable to drop in some befy bolts through the frame
Old Dec 30, 2010 | 02:01 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Post a picture of what you are talking about. Maybe you are refering to the skid bars, which are part of the radiator support and hang down under the bumper cover.
Old Dec 30, 2010 | 02:10 PM
SinisterC6's Avatar
SinisterC6
Speedy
if you look at the tube at the very front of the car, there is a peice of metal shaped like an accordian inside of it that is preventing my from reaching my arm into the tube
Old Dec 30, 2010 | 02:17 PM
timd38's Avatar
timd38
Part of the crash protection system.
Old Dec 30, 2010 | 02:22 PM
SinisterC6's Avatar
SinisterC6
Speedy
thought so, it doesnt look like gm wantd it to be removable, gues im going to make a hole and slip bolts through the top
Old Dec 30, 2010 | 06:13 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If the hollow cross-beam is replaced, I think the accordian-shaped impact absorber inside gets installed as a separate part. If that's true, and I can't guarantee it, then you can probably remove it for your work.
Maybe a body shop that does Corvette work will know?
Good luck!
Old Dec 30, 2010 | 07:31 PM
hebdog7's Avatar
hebdog7
It is a crumble zone designed to take the inertia from an impact and crush itself instead of transferring to the passenger compartment. I myself would not mess with it, but that is me.
Old Dec 30, 2010 | 08:05 PM
SinisterC6's Avatar
SinisterC6
Speedy
me neither, i realized there is a difference in modding and hacking, i drilled a hole just larger than my bolt head and can fish it through, the frames on these cars are harned steel, it ate 2 drill bits, just got back from home depot with a cobalt bit, hopefully that does the trick
Old Dec 30, 2010 | 08:17 PM
hebdog7's Avatar
hebdog7
Dang it! 2 bits and a run to the hardware store! That sucks! I never understood why they did not have any way to hook a tow strap up to these cars. Oh well good luck sir!
Old Dec 31, 2010 | 01:55 AM
SinisterC6's Avatar
SinisterC6
Speedy
Cobalt bit did the trick, drilled my holes, fed bolts through, added washers to make the hook sit exactly where I want it and voila free tow hook
Old Dec 31, 2010 | 02:41 AM
m R g S r's Avatar
m R g S r
I was gunna say get a fresh cobalt bit and use cutting oil to drill, slow speed. should be able to get through anything on the car!
To frame rail
