Need help finding a wire
Old Jan 3, 2011 | 08:55 AM
Mojo 97 Vett's Avatar
Mojo 97 Vett
Default Need help finding a wire
Does anybody know where to find the hot wire for the headlights. I recently bought a flameball shift **** that can illuminate at night and wanted to hard wire it in with head so when headlights come at night so will my shift **** and visa versa. I am guessing that I should be looking for the twilight sentinel wire on/off on the relay ?
Thanks in advance
Old Jan 3, 2011 | 09:39 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
It won't be the headlamps, rather it'll be the instrument lights. Go to the fuse box in the passenger footwell.
Old Jan 3, 2011 | 12:40 PM
Mojo 97 Vett
Doesn't the instrument lights stay on full time just get brighter during the day ?
Old Jan 3, 2011 | 03:27 PM
dgrant3830's Avatar
dgrant3830
If they stayed on, then the battery would go dead all the time when you weren't in the car. You also don't need the shift **** to light up during the day either.
Old Jan 3, 2011 | 06:34 PM
Mojo 97 Vett
Let me Re-Phrase
Doesn't the instrument lights stay on full time (with the ignition on ) and just get ( twilight sentinel mode ) brighter during daytime/dimmer at night ?
Old Jan 3, 2011 | 08:03 PM
dgrant3830's Avatar
dgrant3830
You are correct and I was thinking of the C-5. Sorry about that.
Old Jan 4, 2011 | 07:24 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
the easiest source would be to tap the interior lighting circuit, if you pop out the panel for the hatch/ gas cap release buttons you will notice a brown wire going to each switch, splice your shift ***** wiring into either one and it will only receive power when you turn the lights on. you can route your new behind your gauge bezel and under your center console to get to the shifter boot area.
let me know if you have any trouble removing any pieces or locating the wire
Old Jan 4, 2011 | 03:24 PM
Mojo 97 Vett
Thanks for the help !
I Love this forum
Old Jan 4, 2011 | 03:49 PM
hebdog7's Avatar
hebdog7
You can also wire it form the radio. Just find a wiring schematic and find the corresponding wire for the lights.
To Need help finding a wire
