19" wheel widening?
Old Jan 3, 2011 | 11:24 AM
Robls6's Avatar
Robls6
Default 19" wheel widening?
Can the stock 19" rear wheels (non widebody) be widened to make a wider tire fit under the stock fenders? I know you can do this with an 18" wheel, but I want to keep the 19" in the back. Does anyone make a tire that will fit a stock rear 19" wheel that is widened 1"?
Old Jan 3, 2011 | 11:29 AM
timd38's Avatar
timd38
You can buy them 1" wider, so I see no reason why could not widen the ones you have.
CCW will make you a 12" wheel that fits if you to go that route.
Old Jan 3, 2011 | 11:36 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
The problem is that you'll be adding the 1" to the inside and I think it will rub under the stock fenders. You need a wheel with the proper offset to make it work.
San
Old Jan 3, 2011 | 01:00 PM
FloydSummerOf68's Avatar
FloydSummerOf68
You should be able to widen the stock wheel 1" without any issues.
A 305 would look much better on an 11" wheel than it would on a 10" wheel.
I'm using up the rear tires I have now and will be sending my Crays off to widen them from 10.5" up to 11.5"
Old Jan 3, 2011 | 01:32 PM
Ragtop 99's Avatar
Ragtop 99
That fits the regular C6? I know their 19x11" fits.
Seems like tires for a 12" would stick out too much. I have Invo 325s on my LGs and I think the 305s would look better. Unless there is more room inside the wheel that LG didn't use, 335s & 345s would look weird. Anyone have a photo of this?
Old Jan 3, 2011 | 01:38 PM
timd38's Avatar
timd38
John at CCW told me that they do it "all the time", when I was looking, but decided on BBS wheels instead.
I can't drive well enough to need that much tire.
Old Jan 3, 2011 | 03:12 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Timid, are you sure you weren't looking at an 18X11? I know my 18X13 fills out the wheel-wells nicely, and I have the Z06 rear fenders.
San
Old Jan 3, 2011 | 04:39 PM
Robls6's Avatar
Robls6
That's what I want to do. Keep the stock offset and just put another inch of rubber under the fender. There is room to go towards the center of the car with the tire. So they do make a tire that will fit a
19" x 11" wide wheel?
Old Jan 3, 2011 | 07:08 PM
Boat Racer's Avatar
Boat Racer
I have a set of 1" widened stock 19" rear rims (now 11" wide) and run Toyo R888 305/30/19 tires on them. They don't rub on the inside and don't stick out of the fenders on the outside.
Old Jan 4, 2011 | 06:13 AM
SpinMonster's Avatar
SpinMonster
Proof enough. Can you check to see if it is at least 5/16-5/8" away from the upper control arm?
Old Jan 4, 2011 | 09:25 AM
haljensen's Avatar
haljensen
You can't keep the stock offfset if you add an inch to the back of the wheel. Offset is measured from the center of the wheel so by adding an inch you moved the center of the wheel 1/2" which moves the offset by 12.7mm.
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jan 4, 2011 | 10:00 AM
FloydSummerOf68
I believe what he meant was that he wanted the face of the wheel to be in the same physical location. Not pushed out or in, so yes, after widening 1" to the inside the offset would change.
Old Jan 4, 2011 | 10:52 AM
Boat Racer's Avatar
Boat Racer
I took those wheels and tires off the car for the winter, so won't be able to do any measuring until spring time.
Old Feb 8, 2012 | 05:40 PM
nch209's Avatar
nch209
Along the same lines, is it possible to add an inch to stock wheels on the inside, and mount a OEM supercar tire from a Z06 with no rubbing issues (of control arm)?
Nevermind... this answers my question
http://forums.corvetteforum.com/c6-t...options-3.html
To 19" wheel widening?
