dual spring?
Old Jan 3, 2011 | 06:32 PM
z06 hellcat's Avatar
z06 hellcat
Default dual spring?
is it ok to put a set of dual springs rated for 660lift on a cam with about 580lift? im not sure if it will cause abnormal wear verses a lower rated spring.
Old Jan 3, 2011 | 06:43 PM
timd38's Avatar
timd38
I don't see an issue, but if I was you I would check with the cam supplier.
Old Jan 3, 2011 | 08:50 PM
Gering's Avatar
Gering
Tolero Apto Victum
Here are the dual springs that I run: http://www.livernoismotorsports.com/...t.phtml?p=1575
Give them a call, they are very helpful.
To dual spring?
