Z06 rear end
Old Jan 4, 2011 | 12:15 PM
dboelens's Avatar
dboelens
Default Z06 rear end
I'm looking to change gears in my C6. I know a Z06 rear end will not fit in a C6 but I remember reading somewhere where there is a kit you can buy so that install can be accomelished. Anyone know anything?
Old Jan 4, 2011 | 12:41 PM
ITS STOCK's Avatar
ITS STOCK
If you have a 2006+ you will need a z06 tailhousing and 30 spline mainshaft to put the z06 rear in. If you have a 08+ you will need the tr6060 z06 tailhousing and mainshaft.
Old Jan 4, 2011 | 12:56 PM
dennis50nj's Avatar
dennis50nj
the z06 rear can be put in, but you can only use 342 gears i think
Old Jan 4, 2011 | 01:04 PM
LS1LT1's Avatar
LS1LT1
That's with a manual, on a 2006 and up automatic I believe it's much easier.
Old Jan 4, 2011 | 02:29 PM
C6Phil's Avatar
C6Phil
How about on a 2005 A4?
Old Jan 4, 2011 | 02:49 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Is your car an automatic or manual?
Old Jan 4, 2011 | 05:01 PM
dennis50nj's Avatar
dennis50nj
yes you can all you need is to change the a4 mainshaft and the adapter and zo6 rear
Old Jan 4, 2011 | 05:50 PM
dboelens's Avatar
dboelens
My car is an A6 2007
Old Jan 4, 2011 | 05:58 PM
thesubfloor
Call Pfadt Racing, order their "offset differential mounts" and voila, it becomes a straight bolt-in without any needed changes to the transmission.
Since the Z06 comes with integrated cooler lines you'll have two choices regarding those - either leave most of them intact and install a loopback hose (on the little supplemental cooler on the left side of it) or you can plug the lines and install a replacement cover (from Zip Corvettes, I believe) to remove the cooler entirely.
To Z06 rear end
