Axel Click/ Repair steps
Old Jan 5, 2011 | 10:37 AM
donnief88C6's Avatar
donnief88C6
Default Axel Click/ Repair steps
Does anyone know a link to a thread that has the steps to lube the axels step by step with proper tourqe specs? thanks
Old Jan 6, 2011 | 09:52 PM
softy91's Avatar
softy91
Default Axel click
The click is from a axel nut that is not torqued to spec, usually the passenger side. It is a common problem and a trip to the dealer will get it fixed under warranty.
Other wise you can do the repair yourself by picking up a new axel nut. Torque spec is 160 Ft lb and lock tight.
Good luck!
Old Jan 7, 2011 | 03:55 PM
vetracer's Avatar
vetracer
Here's a thread I did on it:
http://forums.corvetteforum.com/c6-t...r-r-fixed.html
To Axel Click/ Repair steps
