Tunnel Support Plate
Old Jan 9, 2011 | 05:38 PM
TINCANMAN's Avatar
TINCANMAN
Default Tunnel Support Plate
just curious to know the difference if any in the way your c6 feels after switcthing to after market tunnel plate . thanks in advance
Old Jan 9, 2011 | 05:44 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Opinions vary. Search is your friend.
http://forums.corvetteforum.com/c6-t...nel-plate.html
San
Old Jan 12, 2011 | 09:59 AM
CMY SIX's Avatar
CMY SIX
yes the car feels stiffer, that being said, I got the 1/4 ceramic coated one form elite eng and the inside of the car is much cooler.
Old Jan 12, 2011 | 10:36 AM
mitchydkid's Avatar
mitchydkid
I put a 3/8" ceramic coated plate on my car. I can't tell much if any difference in handling. The car stays cooler inside...for a while...but on long trips the heat eventually builds up and makes its way into the car. That being said, I've never found the cabin heat to be all that bad. Its not like a Viper.
-D
Old Jan 12, 2011 | 01:10 PM
HOXXOH's Avatar
HOXXOH
Other than a slight reduction of cabin temperatures (when not moving), the biggest advantage of a thicker plate is to lower the center of gravity. A drawback is having to haul around the extra weight.
From an engineering standpoint it will not stiffen the chassis measureably. The mounting holes are .41 diameter and the screw is .23 and only tightened to 89 inch pounds torque. The .125 thickness is attached to six seperate .05 thick steel sheet metal angles. When you recognize the close proximity of the exhaust pipes and the fact that aluminum has an expansion rate of 3 times that of steel, you'll understand why those attachment holes, screw sizes, and torque specs exist. Thermal expansion and required assembly tolerances are the influencing factors for the heat shield that is commonly called the tunnel plate. Chassis stiffness plays no role in the design.
If one wanted to improve the design, a scoop directing cooling air around the exhaust pipes would be one direction to investigate.
Old Jan 12, 2011 | 01:24 PM
Ragtop 99's Avatar
Ragtop 99
My roof creaking decreased immediately after I installed the Elite 1/4" unit. It wasn't night and day in feel, but the noise reduction was measurable.
same. It takes an additional 15 - 30 minutes to warm up to where it was w/o the plate. In the summer, the cabin still warms up too much.
Old Jan 12, 2011 | 01:46 PM
HOXXOH's Avatar
HOXXOH
The thickness would have no effect on the roof, but the torque on the bolts might. If the originals had loosened (and they do) and/or the torque was excessive when the new unit was installed, then the body flex could be affected.
Old Jan 12, 2011 | 02:52 PM
Ragtop 99's Avatar
Ragtop 99
I had to R&R the factory plate for my header install so they did not have the factory installed torque prior to deciding on trying the Elite plate. I don't recall the bolts being loose either when the Elite plate went in, but unless it just about fell off, I doubt any thought would have been given to it.
Old Jan 12, 2011 | 03:11 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Installed the Elite ceramic coated plate on my '05 Vert couple of years ago.....hard to judge if there was an actual improvement in chassis stiffness, but it feels tighter. Also, as others have noted, reduced transfer of exhaust heat into the cabin.
Old Jan 12, 2011 | 05:22 PM
NORTY's Avatar
NORTY
I have the Elite .250" plate. It's been there for 4+ years. The stock plate is .140". I noticed a slight torsional stiffness change, but now I'm used to it. I had to grind some exhaust coller material off as it rubbed while WFO.
The heat issue: It does help, but eventually, the exhaust saturates the thicker plate too. Once this is done, it'll take the plate longer to cool off as it has more mass.
Weight difference is negligable.
I talked with my trusted GM engineer, and he said the C6 is certified for crashworthiness with the standard plate installed. Any change to this may change the energies transferred during an impact. For this reason, he suggested not to mess with the stock plate. (I'd already made the change.)
Old Jan 13, 2011 | 08:47 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I think we need to stop confusing chassis stiffness with body panel stiffness. The thicker tunnel plates will do virtually nothing to improve chassis stiffness, but they might help stiffen the body panels and reduce flexing. I'd guess most people that report "chassis stiffening" are vert owners, who don't have the body stiffening structure of the halo.
Anyway, stiffening the body panel can have positive results on the track, even if it is just because the driver FEELS more confident, not because of any structural improvement.
To Tunnel Support Plate
