brake light relay
Old Jan 10, 2011 | 03:23 PM
Ron J's Avatar
Ron J
1st Gear
Default brake light relay
when brakes are applied or released I can hear the relay clicking,the dealer says it's normal. Whats the solution? Thanks, Ron J
Old Jan 10, 2011 | 04:34 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
install loud exhaust is the fix. ive never noticed it. only thing i hear is the top creeking and popping
Old Jan 10, 2011 | 04:42 PM
ebf2k's Avatar
ebf2k
St. Jude Donor '12-'13-14
I noticed the same thing right away. I've been told it's normal too. Dealer I purchased from said it started making that click with the '10 model.
Old Jan 11, 2011 | 12:26 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
I have an 07 that clicks, its the relay that gm choose, if you take it out and go to any parts store they can source you a quiet one
Old Jan 11, 2011 | 08:47 AM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
I was under the impression that the BCM controlled the brake lights, not a separate relay.???
Old Feb 15, 2011 | 07:48 PM
KENS80V's Avatar
KENS80V
The relay mentioned is installed on the BCM. It is located right next to the fuses on the BCM. On the back side of the BCM is the reverse lights relay. Both are "TYCO" brand relays.
To brake light relay
