Dyno testing
Old Jan 12, 2011 | 10:05 AM
musicman2's Avatar
musicman2
Default Dyno testing
Has anyone dynoed their Vette in -----85 degree --high humidity----vs----50 degree--low humidity---Same car, same mods----How much difference was there in RWHP ???? How about the difference in your 1/4 mile times under each of these circumstances ?? Seems like in the cooler fall weather, the Vette seems to be much stronger, often wondered if it was mostly our imagination or not !!----THANKS !!
Old Jan 12, 2011 | 10:35 AM
dennis50nj's Avatar
dennis50nj
yes their is a diference, check the DA, every 1000 ft. of DA change is = to 3%% of your rwhp, they say dynos correct for weather.
Old Jan 12, 2011 | 11:01 AM
smurfkiller's Avatar
smurfkiller
yes the cold air makes more power. as the cold air is more dense which means more oxygen molecules per cubic foot of air. true the dyno is supposed to correct for temp/humidity/elevation etc. but i have seen a diff of as much as 15 hp from middle of summer to winter on the same car.
Old Jan 12, 2011 | 01:59 PM
Vito.A's Avatar
Vito.A
A dyno corrects ambient temp, pressure altitude, and humidity for a standard day. A standard day is 60 degree F, 0% humidity, and 29.92 inches of mercury. It is actually possible to get a higher dyno number on a hot day than a cold day because of the correction factor.
A temp change from 85 to 50 degrees will make a large change in performance at the drag strip. The other large factor is the pressure altitude. Humidity affects density altitude, but not nearly as much as temp and pressure. NHRA has a correction factor formula they used to use for National records. They discontinued it for the Pro classes as Phoenix in Feb has very dense air (in spite of the elevation) and had several of the records.
To Dyno testing
