Black Widow Cam
Old Jan 16, 2011 | 09:34 PM
z06blk's Avatar
z06blk
Navigator
Default Black Widow Cam
Just got my vette running today, 2006 Z06 - I added a black widow can and cold air intake from Vette-Air. Carlos was a great help. I was able to call him and he talked me through everything I needed also he provided me a tune for the car. It sounds and runs great!
http://www.youtube.com/watch?v=L3QvP7AkZjc
Thank you Carlos!!!!!!!
Old Jan 16, 2011 | 10:55 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Sounds great, congrats!!
Old Jan 16, 2011 | 11:45 PM
Daredevil95's Avatar
Daredevil95
sounds nice......what are the cam specs and did you have to change springs and rockers? Sounds awesome!!
Old Jan 17, 2011 | 01:21 AM
z06blk's Avatar
z06blk
Navigator
Changed the springs and used the stock rockers
Intake is 246 duration an 660 lift exhaust is 252 duration an 649 lift
Old Jan 17, 2011 | 02:56 AM
SpinMonster's Avatar
SpinMonster
What are the springs/specs and what lift are they rated to?
.660" lift is huge.
Old Jan 17, 2011 | 09:37 AM
JoesC5's Avatar
JoesC5
To me, if I were planning to soup up my Z06, it would be worth going a few more cubic inches by using a iron bock(118 lbs more then the LS7 block) LSx454(fully forged). With LS7 heads at 11.5 CR, comp cam 262/270 deg & .686/.658 lift w/LS7 rockers. Use a ported LS7 intake, PTM 92mm and fast 50 lb injectors and a TSP 100mm MAF. Results....692 FWHP@6700 and 617 lb/ft@5,200. That's approx 608 rwhp NA.
http://www.highperformancepontiac.co...454/index.html
Old Jan 17, 2011 | 10:42 AM
z06blk's Avatar
z06blk
Navigator
Don't know the spring ratings, I got the package from Carlos at Vette-air. He has used it many times and it seams good.
www.vette-air.com
Old Jan 17, 2011 | 12:16 PM
Daredevil95
NICE....that will fly......I could hear in the sound in that cam. The duration seems big....hows the low end power?
Old Jan 4, 2017 | 04:50 PM
ZICK's Avatar
ZICK
Great Cam
Same that I have
To Black Widow Cam
