Lowering F55
Old Jan 16, 2011 | 10:17 PM
Ursoboostd's Avatar
Ursoboostd
Default Lowering F55
So I've been searching.....Here is the most helpful thread I've found so far, but didn't really ansewer my question. If I decide I want to lower behond the stock bolts should I not buy a C6 with the F55? Thanks for any help. -Wade-
http://forums.corvetteforum.com/c6-c...re-system.html
Old Jan 16, 2011 | 10:31 PM
Ursoboostd's Avatar
Ursoboostd
Did a little more searching, and I guess I ansewered my own question. Lowering behond the stock bolts is a bad idea on the F55 MR sus. Sucks, I was just about to got look at a 08 with F55, but this may change my mind.
Old Jan 19, 2011 | 12:54 PM
Pfadt Racing's Avatar
Pfadt Racing
Ursoboostd, The OEM shocks are going to be the limiting factor for travel, regardless of the platform. They have a certain amount of travel in them that is accounted for from the factory.
The way to properly lower the car and retain full travel is with coilovers. This system would supersede the OEM dampers and leaf springs. At bare minimum, you can also purchase shocks that have slightly more travel engineered into them, to help out with lowering on the OEM bolts.
Let me know if you have any questions.
Old Jan 19, 2011 | 07:28 PM
BEZ06's Avatar
BEZ06
I had a 2005 Coupe with F55. It looked STOOOOOPID the way it came from the factory!!!!! The azz end was jacked way up in the air and there was a huge gap between the tire and the fender well, especially in the rear.
I lowered it in the front not quite all the way down, and in the rear all the way down on the stock bolts. The rear was still not where I wanted it, so I cut the bushings.
I drove the car that way for about 35,000 miles, and I sold the car to my brother-in-law 2 years ago and he has put another 10,000 or 15,000 miles on it roads in the northeast. The car has no problems at all being lowered on cut bushings.
I've got the F55 equivalent on my ZR1 now - but it sits perfect just the way it came off the assembly line!!
I say - if you want to lower a car with F55, go ahead and lower it. If getting where you want it means you need to cut the bushings or install aftermarket bolts, go ahead. My experience is that there's absolutely no bad effects on the F55 from lowering it.
Bob
Here's my 2005 Coupe with F55:
Old Jan 20, 2011 | 08:01 AM
5.4ever's Avatar
5.4ever
Bob
a little off topic but what color is that???
Old Jan 20, 2011 | 10:45 AM
BEZ06's Avatar
BEZ06
DSOM!!!
My '05 Coupe and '06 Z06 were DSOM, but they discontinued it after the 2006 model year.
After all, I do live in Daytona!
I would like to have my ZR1 in that color as well, but it's not available anymore, so I had to settle for Cyber Gray.
Bob
Old Jan 20, 2011 | 03:25 PM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
DSOM!!!
Bob
Sorry Bob, but "settle for" and "ZR1" just don't go together
Kevin
To Lowering F55
