Disable ABS for drag racing?
Old Jan 19, 2011 | 09:10 PM
blackbird345's Avatar
blackbird345
Default Disable ABS for drag racing?
Does anyone find they need to do this?
Old Jan 19, 2011 | 09:17 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
No. There's no reason to mess with your antilock brakes, nor can you (except pull the fuse I guess).
If you mean active handling, I turn off traction control - one click. Leave active handling on, it just might save you if you get out of whack down track. It doesn't slow you down.
Old Jan 19, 2011 | 10:28 PM
blackbird345
I turn off both active handling and traction control, but someone told me that the ABS will still kick in if your back wheels are bigger than your front or something...
Old Jan 19, 2011 | 10:46 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
good question, im planing on running 28" slicks in the back and the 26" racemasters up front. ut roh!
Old Jan 20, 2011 | 12:19 AM
craftfox's Avatar
craftfox
lol, no, none of this is true.
your abs does not effect your car in any way shape or form, unless you touch the peddle.
Old Jan 20, 2011 | 07:00 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Only traction control kicks in with a f/r wheel discrepancy.
If you want to disable abs still however just pull the fuse
Old Jan 20, 2011 | 09:17 PM
30YR W8T's Avatar
30YR W8T
Wouldn't even think about doing this, there is no need.
To Disable ABS for drag racing?
