XM Radio Crashed
Old Jan 22, 2011 | 10:37 PM
Tim Coltrain's Avatar
Tim Coltrain
Default XM Radio Crashed
I was on a trip the other day and while driving I was listening to the XM radio then all of a sudden it went dead. I hit the band button went to AM, FM, then CD. All played without a problems. Then it would not go to XM at all. So, I talked to my service manager and he siad it sound like a xm converter box under the console had gone bad. There was bullinton on this per him. Has any one had this problem before and was the fix an easy fix. I hate things getting torn up to fix something simple. Any feed back appreciated.T
TIM$VETT
Old Jan 24, 2011 | 08:43 AM
C6nexttime's Avatar
C6nexttime
best thing is to take it to the dealer if its under warranty
Old Jan 24, 2011 | 09:06 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree. You could also try pulling whatever fuse for the XM module and see if it reboots.
Old Jan 24, 2011 | 09:19 AM
Schoolteacher's Avatar
Schoolteacher
TIM$VETT
Mine started cutting out so I canceled service, and now the xm people wont leave me alone
Old Jan 24, 2011 | 09:27 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
1st and easiest thing to check is the connector at the XM Tuner.
Under the carpet behind the drivers seat.
If it's loose, the head unit won't know the tuner's there and will not display XM1 or XM2 bands.
Old Jan 24, 2011 | 10:21 AM
Tim Coltrain
Default XM Crashed
Thanks, I'll look under the seat. It was there, then it disappeared.
TIM$VETT
Old Jan 24, 2011 | 01:50 PM
nrsnik's Avatar
nrsnik
The XM module is not under the seat. It is above the driver's side rear wheel.
This link will help you find it.
http://forums.corvetteforum.com/c6-c...w-sir-gm1.html
Old Jan 26, 2011 | 09:03 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
This happens to me in the Hummer every once in a while. I normally disconnect the battery for about 30 minutes and it comes back.
Old Feb 17, 2011 | 08:48 PM
Tim Coltrain
Default XM Follow Up
Just wanted to let you guys know I appreciate all the help you gave me trying to figure out what was wrong with my XM radio. I ended up carrying it to the Dealer. They found out that the reciever had gone bad. They are replacing the reciever box. This one is somewhere around the back side of the radio. I should be able to pick my baby up tomorrow. Tks again
TIM$VETT
To XM Radio Crashed
