Obd ii p0422
Old Jan 24, 2011 | 10:14 PM
BruinsInSpace's Avatar
BruinsInSpace
Cruising
Default Obd ii p0422
Hello,
My check engine light came on the other day, so I bought one of those OBD II scanner devices to see what the problem was (the machine cost half of what Chevy charges to diagnose it). It says "P0422". I erased the code, though, and now I am thinking that it actually was P0442, instead.
The causes are:
p0422 Main catalyst efficiency below threshold
p0442 evaporative emissions system small leak
Are these worth taking the car to the mechanic over? It sounds like something that I shouldn't worry about until I have to get it smogged...
Car info: 2005 coupe 6MT
thanks!!
Old Jan 24, 2011 | 10:55 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Well, wait for it to reappear. Then write the code down.
Either one could cause you to fail your emission test. Just keep checking then look for the cause.
Old Jan 24, 2011 | 11:19 PM
BruinsInSpace
Cruising
Thanks! I drove the car briefly, and the light has not reappeared yet. If it is just emissions related, I have 1.2 years until I have to do a Smog test. I am just concerned if it has the potential to damage the engine.
Old Jan 25, 2011 | 12:34 AM
Bill Dearborn's Avatar
Bill Dearborn
If it is the catalyst code and it comes back take it to the dealer. That code indicates the cat isn't working properly. The cats are covered under the 8 yr/80K mile emissions warranty required by the government so unless you are over the 80K the car is still covered.
Bill
Old Jan 25, 2011 | 09:47 AM
BruinsInSpace
Cruising
Bill
My car only has 37K miles on it, so I guess I am under warranty. I didn't realize that the cats have a longer warranty period. If the light comes back on, Ill take it to the dealer. I'll let them use my scanner so they don't charge $100 to read the light
Old Jan 25, 2011 | 10:17 AM
Mez's Avatar
Mez
Have you installed headers or any other mods? That could void your warranty depending on if the dealer concludes that is the cause.
To Obd ii p0422
