Valve Spring Replacement while in Car!!!
Old Jan 24, 2011 | 10:24 PM
SearayC5's Avatar
SearayC5
Default Valve Spring Replacement while in Car!!!
Hey guys what do you recommend for a tool to compress the springs on an LS7 to change them out. I ordered a Crane Cam spring tool from JEGS that said it was for the LS7,LS3, and L92. Although in the instructions in said "Will not work on LS7". Why is this? Will this tool actually work or does someone have another recommendation?
Old Jan 24, 2011 | 11:51 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Go to ls1tech.com and do a search for "valve spring removal tool". I can't remember his name but there's a guy who sells one that's pretty inexpensive and I've used it on my LS7 several times now.
Old Jan 25, 2011 | 11:48 PM
glennhl's Avatar
glennhl
The Larry Tool. At least that's what it was called when I bought one 6 years ago. You can make one yourself, it's very simple.
Old Jan 26, 2011 | 06:19 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
i second the make one yourself,
as soon as you figure out how it does the job, you can make your own real easy. remember to get the spark plug fitting.
Old Jan 26, 2011 | 06:38 PM
Jon@Texas-Speed's Avatar
0Jon@Texas-Speed
Former Vendor
We use a crow bar style tool from Snap On. Makes it super easy in vettes. If you are going back with a single spring again, a simple screw top compressor is easy to use as well. It's not so good on a dual spring though.
Jon
Old Jan 27, 2011 | 09:13 AM
lockman's Avatar
lockman
I used a tool I got off ebay it's pretty simple although I had to modify it to work on my ls3 allthough it said it was for the ls3 but just had to adjust the hole to make it fit lol. but worked great with a compression tester to put air in the there.
Old Jan 27, 2011 | 12:34 PM
ss2z06's Avatar
ss2z06
Jon
From what I have been told Snap on no longer makes that. I got mine from Tim schroeder. The tool worked great!
To Valve Spring Replacement while in Car!!!
