is map sensor from ls7 same as ls2?????
Old Feb 2, 2011 | 09:51 PM
mario7669's Avatar
mario7669
Default is map sensor from ls7 same as ls2?????
are they the same ls7 and ls2 does somebody happen to have part# thanks for all info
Old Feb 5, 2011 | 10:58 AM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
I can't remember off the top of my head and I don't want to give you the wrong answer so feel free to send me an email and I'll check it out when I get back to the office.
Old Apr 18, 2012 | 11:07 PM
Loandog's Avatar
Loandog
1st Gear
i have what appears to be an LS2 MAP sensor in an LS7 and the scanner shows the barometric presure to be 17 psi when it is actually about 14.7 psi. Did you find out if these engines have different MAP sensors?
To is map sensor from ls7 same as ls2?????
