E3 Spark Plugs?
Has anyone used the E3 before and could you share your experience? Do you think I would have the same "charging challenges" as the other folks?
Also, I'm adding headers, cat back, and CAI. Will this influence which or what kind of plug I should use?
Any feedback would be much appreciated!
I would not waist money on them again.
As for your plugs - why change them? The plugs are good for 100,000 miles. 45k is no reason to change them unles you just want to spend money and time.
If you are going to change them, go with the stock A/C plugs that it came with.
Would you not invest the $40.00 and replace them now?
You are just wasting your money. There will be no performance increase or gas milage increase. I will tell you that you will see no benefit with switching out your plugs. The plugs have nothing to do with being the "weakest link" as you call it in your post. More than likely you will just end up breaking a plug or wire or mixing up the firing order. Don't create a potential problem when you don't have to. You can change your oil every 100 miles too but that doesn't mean you are making anything better. I would leave as is but do as you please.
if they were so great, how come NO manufacturer of high end sports cars, or any sports cars, use them ???
I agree with the OEM plugs as a replacement and agree with you (OP) at 50K they are worn enough to warrent replacement while you have everything out of the way.
I run NGK's and have 0 issues but have read plenty of threads where people had issues with the charging system so I am actually considering going back to the OEM plugs when I do my cam swap.
I already have the wires disconnected and I will kick myself later if I don't just change them now.
Be easy, fellow C6ers
