Superchip 2825 / Can it adjust shifting points
Old Feb 5, 2011 | 11:44 PM
Harry's 81 C3's Avatar
Harry's 81 C3
Default Superchip 2825 / Can it adjust shifting points
I have an 06 VERT LS-2, A6 Paddle shift. I just purchased a used 2825 Superchips flahpaq, My question is, what all can or will this tuner do for my LS-2/A6 VERT? My past experience was with a Cortex for my LS-1 GTO and I noticed the increase in throttle response & power, but I Loved the ability to adjust the shifting points. Does the 2825 Tuner have the same capabilities on an A6?
Old Feb 6, 2011 | 03:12 AM
SpinMonster's Avatar
SpinMonster
Tuning questions will get a better response in the scan and tune section.
Most custom tunes yeild double digit power gains along with all trans specs optimized. A canned tune in such a tuner as you have cant make an optimum tune on any car because a guy living in cold areas at high altitude and sea level car in a really hot climate cant be optimized in the same tune. They have to keep it safe for all areas including places where 91 octane is used in hot climates like southern Cali.
A real tune will be much better if you can return it.
