Are my Z51 rotors facing wrong?
Old Feb 7, 2011 | 06:47 PM
8850's Avatar
8850
Default Are my Z51 rotors facing wrong?
Here are pics of my passenger and drivers side front Z51 rotors. Notice the direction of the holes in each with respect to where the caliper is positioned. They turn the opposite direction. The internal veins are also turning opposite. Both rotors appear to be the same. Were you to install either on the opposite side it would turn the same as the one currently on that side. The rear holes are opposite as well. Have not been off the car since I bought it new. Is this correct?
Old Feb 7, 2011 | 06:50 PM
hungryhippo's Avatar
hungryhippo
yes, that's normal. GM only made one pattern for us.
Old Feb 7, 2011 | 06:55 PM
BEZ06's Avatar
BEZ06
All the Z51 and Z06/GS rotors are "left side" rotors.
So......nothing the matter with your car!!!
Bob
Old Feb 7, 2011 | 06:59 PM
8850's Avatar
8850
Guess I don't have a problem then. Just seems to me air flow would be reduced on the side with the veins turning with air flow (drivers side). I believe with aftermarket there is a right and left side to keep air flow consistent.
Old Feb 7, 2011 | 07:30 PM
8850's Avatar
8850
Bob
So in reality they are suppose to be turning the direction of the passenger side? Seems to me they would cup air and force it towards the center of the rotor the way the passenger side rotates. And on drivers side air would be force the opposite or inside of rotor to OD of rotor.
Old Feb 7, 2011 | 08:46 PM
BEZ06's Avatar
BEZ06
The curvature of the internal vanes is what determines the best side for them.
The OE Z51/Z06/GS rotors are all designed to work best on the LEFT side of the car.
The rotor should be designed to pump air away from the center of the rotor to the outside edge - like they will do properly when mounted on the left side of the car.
They work on the right side, just not as well as they would/should if they were designed correctly, like most high-end aftermarket rotors.
The worst thing about the rotors is the holes in them - they are purely for bling!!!!
Virtually all the rotors used for the track by the HPDE crowd and hard core racers will not have holes in them - they may have slots, and sometimes dimples, but NO HOLES!!!
Bob
Old Feb 8, 2011 | 12:12 AM
HOXXOH's Avatar
HOXXOH
And if you look carefully, the rear rotor air intake is on the outside, yet the cooling tube directs air to the inside.
At least base rotors draw air correctly and are bi-directional.
Old Feb 8, 2011 | 09:00 AM
8850's Avatar
8850
GM's reasoning doesn't make a lot of sense.
BEZ06, good info!
Old Feb 8, 2011 | 12:17 PM
Gering's Avatar
Gering
Tolero Apto Victum
Sir, just to give you a heads up. I replaced my 07 Z51 rotors with these and like them a lot. http://shop.performanceafx.com/C6-Z51-Corvette_c15.htm They are very lite and last a long time. I run GM pads with them as well.
Old Feb 8, 2011 | 12:32 PM
8850's Avatar
8850
Wouldn't mind having a set. They do say the base save 3.75 pounds over stock. Not a lot of savings for almost $700 bucks. Don't give a weight savings for the Z51 so I would assume about the same.
Old Feb 8, 2011 | 12:37 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
you must be talking only about the front rotors; the rears, per the site, are another 400 or so each. for street rotors, not inexpensive but I guess quality counts for something.
Old Feb 8, 2011 | 12:43 PM
Gering's Avatar
Gering
Tolero Apto Victum
I have been very happy with them & will order another set when needed.
Old Feb 8, 2011 | 12:45 PM
HOXXOH's Avatar
HOXXOH
There is no technical info on their web page, but I'm curious about the actual weight and durability. Roughly how many miles plus hours of track sessions have you logged since using them and how much useable rotor thickness remains?
I'm not yet ready for new rotors, but weight will be a major factor when that time comes.
Old Feb 8, 2011 | 12:56 PM
Gering's Avatar
Gering
Tolero Apto Victum
I talked to AFX, which has a great customer service, and they said it is about 7.5 lbs per front rotor & about 6 lbs per rear rotor. You can also buy the rotors with out slots as well.
Old Feb 8, 2011 | 01:03 PM
Gering's Avatar
Gering
Tolero Apto Victum
My DD (07 A6 Z51) has over 100,000 miles on it. I drive it hard but do not track it, yet. I have over 32,000 miles on the rotors with no problems. I do not know the thickness at this time.
Old Feb 8, 2011 | 01:23 PM
8850's Avatar
8850
Yes, front only. If you add each up they are $1368 for a set of base and $1596 for Z51 plus shipping.
For my type of driving GM base rotors, though I have a Z51, will probably last 100K miles. But like HOXXOH, weight savings would be a major factor. Gering says they told him a 27# saving over stock Z51. If that's actual then quite a good weight savings. Still pricy at over $1600 w/shipping.
Old Feb 8, 2011 | 05:56 PM
SpinMonster's Avatar
SpinMonster
My Z51 stops fine.
To Are my Z51 rotors facing wrong?
