I'm looking to get a header back exhaust this week but came across a lot of different information.
Looking for some clarification on if my LS3 should receive a 1 3/4" or 1 7/8"? If I go 1 7/8" should I just keep it 3" all the way back or will the drop from 3" to 2.5" not make enough of a difference?
Currently looking at Stainless Work's Header-Back exhaust (Link )
It has been well documented on the forum with the LS3 you want 1-7/8" headers with 3" all the way back to right before the catback transition to 2-1/2". That's what I'm going to use on my 10' Grand Sport
We offer Kooks Long Tubes in both 1 3/4", 1 7/8" and a stepped design that goes from 1 3/4" to 2".
What are your plans for the car? If you plan on extensive mods go ahead with the 1 7/8" or the stepped.
Give me a call if you have any questions.
Tom 1-800-962-9632 ext 240.
The car will be pure bolt ons. Planning on ordering Heads/Cams/Intake and headerback exhaust this weekend. From there get a intake mani and TB. I was talking to another vendor who said 1 3/4 will be good.. Just so confused
Who makes a LT header & x-pipe that goes from 3" to 2.5" just before the axle-back? What's the purpose of using this, can it be easily converted to accommodate a 3" axle-back in the future?
I got a 10 MN6 GS......I'm going with the kooks 1 7/8 with a kooks z06 3in catted x and z06 borla stinger axleback.
If you keep it all z06 it will work...Get the 1 7/8 and 3in exhaust call it a day and never have to deal with it again.
The 09+ cars have a different exhaust setup where the axleback hooks up to the x pipe. So you either have to get the 09+ x pipe or keep it all z06.
Will you give up a few feet of TQ? possibly, but once you get to bigger mods they will help you out.
you can get an x pipe that starts at 3in where it connects to the headers and ends at 2.5 at the axleback.
So if I purchase the Z06 system, it will bolt up to my Base C6? There isn't a different setup with the piping?
No he meant if you want to buy a used Z06 catback then you can use it with Z06 headers on your car, but beware if it is an auto it may be very tight back there you might rub in spots. You need 1-7/8" headers with a 3x3 center section with a neckdown at the very end to 2.5" to mate up to you stock exhaust. The 09-up uses a different center section than the 05-08' so be sure you order the right one.
I know what LG thinks and it is different than what most everyone else is actually doing in practice. While the LG's might make a little more low end tq, you have to deal with slip fit collectors that are a pain to remove and often leak and rattle down the road. I don't need to research the matter any further as I've already made an informed decision based upon actual dyno numbers. Having seen several back to back dynos on the same LS3 cars giving up essentially nothing below 4k and picking up nicely above that with the larger primaries - was more than enough to convince me. The largest Kooks distributor there is has verified that on the LS3 there is no lowend loss over the smaller primaries, and it leaves more top end and room to grow. No one ever agrees completely on anything around here so this doesn't bother me a whole lot. Go with the smaller headers if you want, but you will regret it
The larger pipes were done to focus on higher end HP, which is also the reason for a shorter pipe. We also had to work within the space limiations of the car between the bellhousing and the frame with the larger pipes, which placed the collector there.
Personally,
Unless you are going forced induction the 1 3/4" is going to make more total power across the board and really focus in on torque production, which in the end is what makes the car fast.
Only in a few occasions have we used the larger pipes on an LS3 and it made any kind of difference on increasing power over the 1 3/4 systems.
Blown and bigger cube engines...it is a slightly different story but I even use the 1 3/4" on a lot of the LS7 pacakges as well.
Think I'll just do 1 3/4 and call it a day.. The power gains are going to be nominal going to 1 7/8 and I wont be using Forced Induction.
From: Cape May, NJ; Guntersville, AL; Orange Beach, AL
If you aren't doing FI then you won't notice a difference between the 1 3/4 and the 1 7/8. I've seen a lot of FI cars that are even using the 1 3/4. I'm planning on a SC in the future but I've ordered the 1 3/4 LG superpro's with hi-flow cats. If you shop around you can get a good deal on the headers. Good luck with your choice.
