ls2 fuel pump limit?
Old Feb 11, 2011 | 01:58 PM
Stang's Bane's Avatar
Stang's Bane
Default ls2 fuel pump limit?
How much na power can the stock pump handle?
Old Feb 11, 2011 | 03:12 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I'm running a bit short at 485 RWHP.
Elmer
Old Feb 11, 2011 | 03:26 PM
Stang's Bane
Thanks Elmer.
that is what I was scared of.
Okay next question, what is the inlet/outlet configuration of the stock pump. I am trying to match it up to the appropriate 255 style pump.
This is the pump I am considering
http://m.ls1tech.com/forums/showthread.php?t=1363937
Old Feb 11, 2011 | 03:30 PM
eboggs_jkvl
Moderator emeritus
I just received my 340 yesterday from UPS. That pump will do nicely for a little over 500. After I get my install done, we'll tweak the tune and peak out the PE settings and see how we do as we get near the 500 numbers.
http://forums.corvetteforum.com/c6-f...-340-pump.html
Elmer
Old Feb 11, 2011 | 03:36 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Keith, IMO that 340 pump would support ~700 RWHP witout a BAP. Well over 600 fo' sho'.
Old Feb 11, 2011 | 04:21 PM
C6-13thPilotCar's Avatar
C6-13thPilotCar
I running 665 rwhp and 625 tq with boast a pump.
Old Feb 11, 2011 | 05:10 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
stock ls2 pump + BAP at 630whp
hopeing to switch to that aeromotive 340, just waiting for eboggs to get off the forum and do his first! :poke:
lol
-Carl
Old Feb 11, 2011 | 05:17 PM
07MontRedcp's Avatar
07MontRedcp
hoping to switch to that aeromotive 340, just waiting for eboggs to get off the forum and do his first! :poke:
lol
-Carl
Looks like we're in the same boat on this one. I was planning on putting in a Z06 pump in place of my C6 pump and BAP. Now I'm looking at the Aeromotive 340 and selling my new uninstalled Z06 pump.
BJK
Old Feb 11, 2011 | 05:20 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Originally Posted by Stang's Bane
Thanks Elmer.
Here is mine. The pump on the right is the factory Walbro. The pump on the left is a GSS340 HP 255 lph. The 255 that matches the factory Walbro is the GSS342 which has the inlet and the outlet offset. I used the 340 solely because of the large central inlet.
............340..................... 341........................342
Old Feb 11, 2011 | 05:34 PM
eboggs_jkvl
Moderator emeritus
lol
-Carl
Well smarty pants I had to have the darn thing to install it! I'm going to contact my installer and get the change scheduled.
Elmer
Old Feb 11, 2011 | 05:43 PM
07MontRedcp
Elmer
BJK
Old Jul 15, 2011 | 01:49 AM
James Short's Avatar
James Short
I hate to bring this back from the dead but what do these stock pumps support without any boost-a-pump? I started tuning on a LS2 C6 yesterday and it has Kook's LT's, Xpipe and borla exhaust with a MagnaCharger 2300. We custom spec'd a cam for him as well 227/243 117lsa 113icl and with a 2.8" pulley it's building right around 7psi but above 5200rpm it starts starving for fuel. I've added a bunch of fuel through the injectors but it doesn't matter what I do it still starts going lean. We haven't had a chance to get a pressure gauge on it to verify but we are 99% positive that it's the fuel pump.
This same car made 519rwhp when it was stone stock with the blower only on it @ 6.5psi. I'm nearly positive that the cam and longtubes has picked him up tremendously but was wondering what the pump would support. Looks like it will be getting a walbro pump in it now.
Old Jul 15, 2011 | 07:34 AM
taken19's Avatar
taken19
Track Junky
I have heard that the stock LS2 fuel pump will support 525-550 rwhp. Seeing that you have a blower on this car, it will most likely be less since the AFR will be richer than an N/A car. You are most likely out of pump at this point.
Old Jul 15, 2011 | 08:54 AM
carlrx7's Avatar
carlrx7
500whp is what my car maxed out before i added the bap. car would go lean at 5200rpms as well.
HOB Eliminator solved my problem
Old Jul 18, 2011 | 02:27 AM
James Short
Thanks for the clarification fella's we are going to put a Walbro pump in there for him and get it retuned. With the mods this thing has we are hoping for mid 600's to the tire.
I'm still not fond of this blower however cause it heat soaks so fast. IAT's go from 90* to 130* in one gear....
To ls2 fuel pump limit?
