brake bleeding
Old Feb 24, 2011 | 11:53 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Originally Posted by BEZ06
Excellent!!! Sounds like you'll have a great system!!!
I use a Motive Power Bleeder with a GM cap adapter like others have mentioned.
It's designed to put fluid into the bottle, but I think many/most of us just use it as a pressure source. You could probably build your own out of a pump-up bug-spray or fertilizer-spray tank, a pressure gauge, a length of tubing, and cap that will fit the clutch m/c.
Bob
just ordered
Old Feb 25, 2011 | 12:32 PM
Chris_B's Avatar
Chris_B
Originally Posted by SinisterC6
How does conventional bleeding compare to the power bleeder?
Conventional bleeding gets the air out, but takes a little longer and requires more people.
Power bleeding is quicker, but also forces moisture into your new, 'dry' brake fluid -- unless using the much more expensive power bleeders with an internal diaphragm to separate the brake fluid from atmospheric air. Many people claim to use power bleeders with success, which is fine. But I won't use them.
I've been around professional race teams for over 20 years and have never seen a pressure bleeder used at the track or in the race shop. Granted, the teams have people available to do it manually (it takes about 3-4 minutes with 6 people). They also cannot afford to use anything but the best fluid as dry as was packed in nitrogen and sealed from the chemical plant. While they change fluid regularly, we tend to keep in street cars too long. Brake fluid should be changed every two years at the maximum, more often if in higher humidity climates and still using OE rubber brake lines. Forcing atmospheric moisture into fresh brake fluid will shorten up those intervals.
Chris
Old Feb 25, 2011 | 01:07 PM
SinisterC6's Avatar
SinisterC6
Speedy
Chris
good point, i wonder if the use of dessicates in the tank could help?
Old Feb 25, 2011 | 05:53 PM
BEZ06's Avatar
BEZ06
I don't think dessicate in the tank would help.
Actually, I've seen a lot of teams using a Motive bleeder at the track.
You can move the fluid through the system with less than 10 psi and, considering that I just do HPDE's and do plenty of flushing and bleeding for the amount of track time I do, I'm not concerned about moisture from the ambient air being a problem in my Motul RBF 600.
If you're really worried about it, there are pressure bleeding setups that have a diaphragm in them so the air pressure pushes on the diapghragm and the diaphragm pushes on the fluid.
Here's a fer-instance of the rather expensive diaphragm type:
http://www.ntxtools.com/network-tool...BRK-G300A.html
Forum member David Farmer uses bottled nitrogen - commercially available nitrogen is virtually moisture free from the processing. He has a GM brake m/c cap attached to a regulator so that completely dry and inert nitrogen won't introduce any additional moisture into the brake fluid.
So.....if you're really so **** about moisture getting into your brake fluid, there are other methods available.
Bob
Old Feb 25, 2011 | 06:04 PM
SinisterC6's Avatar
SinisterC6
Speedy
Bob
i think the power bleeder will suffice. i drove for 20 miles today and my brakes are neck breakers, conventional bleeding did the trick, no air in the abs, guess i got lucky
Old Feb 25, 2011 | 06:42 PM
Chris_B's Avatar
Chris_B
I'm not sure which type you are referring to, but we are looking for zero moisture and dissolved air, not just a reduction. Quality brake fluid is packaged in a nitrogen environment for this reason (the cheap stuff is not!). That's why once the seal is cracked, we must use it up or throw it out. It's not a real good idea to keep an unsealed bottle lying around for later use, even with the lid screwed on tight.
Chris
Old Feb 25, 2011 | 06:53 PM
Chris_B's Avatar
Chris_B
Yep, that's the type. But for the cost of that kit or the hassle of getting nitrogen fills for the cheaper ones, I'll just stick to the good 'ol manual method and a few beers for the crew (or ice cream if the kids get assigned to the task!).
If we are not that worried about getting moisture and dissolved air into our brake fluid, we should probably not be spending the extra money on the better fluids, such as RBF600 and the like. Moisture is the biggest reason fluid will degrade from its dry boiling point toward its wet boiling point, which is why I generally recommend against the lower cost pressure bleeders. It's kinda like making meatloaf out of USDA Choice filet mignon.
Chris
Old Feb 25, 2011 | 09:17 PM
BEZ06's Avatar
BEZ06
......If we are not that worried about getting moisture and dissolved air into our brake fluid, we should probably not be spending the extra money on the better fluids, such as RBF600 and the like......
Chris
I know you are aware of all the info below, but for others reading the thread here are some specs that may be of interest:
  • DOT 3 fluids must have a minimum dry boiling point (measured with 0% water by volume) of 401F and a minimum wet boiling point (measured with 3.7% water by volume) of 284F.
  • Motul RBF 600 has a dry boiling point of 593F and a wet boiling point of 420F.
Motul RBF 600 has a wet boiling point higher than the dry boiling required of DOT 3 fluid!!!!!!!!
So......I'll stick with the RBF 600 for my track days and use my Motive Power Bleeder to flush before every event and do quick bleeds during the event.
If I were to turn my car into a track-only car, especially if doing W2W racing, I wouldn't think of running anything but Castrol SRF:
  • CASTROL SRF Dry boil pt 590°F Wet boil pt 518°F $69.99/33.8oz
Many guys will put in SRF and just run it all season long - it's that good!!
But.....with SRF costing about 2-1/2 times as much as RBF 600, I'll just stick with what I've been using for a number of years with great success with racing brake pads and R-compound tires.
Bob
Old Feb 25, 2011 | 10:18 PM
SinisterC6's Avatar
SinisterC6
Speedy
Bob
ditto my wilwood fluid is 626, 417
Old Jan 5, 2012 | 08:19 PM
IRS-Cop's Avatar
IRS-Cop
What did you do? Did you remove the calipers from the car - i.e. disconnect them from the hoses that connect them to the brake lines???
If so, and you got them mixed up, that could be your problem.
The soft pedal you describe after multiple bleedings sounds like the problem many have had after removing and reinstalling the calipers. I've read here on the Forum a number of times that people have had issues getting a firm pedal after getting calipers powdercoated or rebuilt, and it's because they put them on the wrong side of the car.
If the calipers are put on the wrong side of the car and the bleed valves are on the bottom of the caliper you'll never get the pedal firm.
The bleed valves must be on the top of the calipers.
Bob
I know this thread is months old and you may never see this post Bob, but just wanted to say a BIG thanks to you for posting this. I was one of those folks who (after waiting a month and a half for my calipers to return from powder coating) installed them incorrectly with the bleeder screws faced down. No matter how much I bled my brakes the pedal never got firm. After searching the forums for quite some time I stumbled across your post. Again thank you Brother!
Mark
