harmonic balancer
Old Feb 27, 2011 | 07:03 PM
RT2SJB's Avatar
RT2SJB
Default harmonic balancer
The dealer replaced my harmonic balancer about a month ago (18k on engine). I was looking at my engine today and it seems the balancer is wobling again. Any ideas why this problem would happen again?
Old Feb 27, 2011 | 07:54 PM
Ragtop 99's Avatar
Ragtop 99
crank bolt wasn't tighten properly.
crank snout was damaged from it being loose.
Old Feb 27, 2011 | 08:24 PM
RT2SJB's Avatar
RT2SJB
crank snout? would the crank need to be replaced?
Old Feb 27, 2011 | 11:21 PM
Walt White Coupe's Avatar
Walt White Coupe
Normal, if the belt isn't chirping.
Old Feb 28, 2011 | 12:17 AM
Greenstealth's Avatar
Greenstealth
If it was damaged from the first pulley. My 05 coupe had the crank pulley fly off and it destroyed the crank snout (where the pulley sits against the crank). That was a bummer but my dealer took care of me pretty well. I have a thread about it somewhere of you feel like searching. I believe the title was "crank pulley flew off tonight wtf"
Old Feb 28, 2011 | 01:41 AM
Rebel 1's Avatar
Rebel 1
Several Brand New Balancers off the shelf have been chucked up and had some wobble.
Old Feb 28, 2011 | 03:04 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Old Mar 1, 2011 | 06:21 PM
journeyc6's Avatar
journeyc6
took my car yesterday to the dealer for same issue at 40K miles, before going to dealer a performance shop mechanic told me a little wobble is normal, but mine was really bad, he told me I was lucky the belt was on. Still waiting to get my car back.
Old Mar 2, 2011 | 09:16 PM
journeyc6's Avatar
journeyc6
got my car back from the dealer today, new harmonic balancer, new belt, no wobble, runs ok.
Old Mar 9, 2011 | 02:24 PM
DaMayor's Avatar
DaMayor
Default balancer repair - Help!
I've got "wobbly balancer syndrome" and the dealer is unaware of the pinning procedure. Does anyone have the GM repair info so that I can provide it to them?
They say, (per my VIN), that I'm out of warranty/recall range so I have to pay the $1,000 repair bill.
2006 C6, 54,000 miles, automatic
Old Mar 9, 2011 | 02:30 PM
Bill Suttie's Avatar
Bill Suttie
Should have bought a GMPP
Old Mar 9, 2011 | 02:40 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
A little wobble is normal. If you indeed have a bad harmonic balancer, go to a reputable corvette/speed shop in your area and have them do an under drive pulley. for the same price, you might as well get the extra 5-10HP for it. (Just my opinion, as that is what I did).
Now, as for $1000 from the dealer, that is much too expensive. A shop that knows what they are doing should be a few hundred cheaper than that!!
There are a few threads on this topic that helped me.
Old Mar 9, 2011 | 02:49 PM
DaMayor's Avatar
DaMayor
I noticed some wobble of the balancer and was able to tighten up the bolt a little with a 24mm end wrench to get to the dealer/stealer. The pulley was about to fly off.
This is actually the second dealer I went to. The first one did not even open the hood for 7 days and was clearly incompetent. The second dealer now has my car.
I will gladly accept donations to my Vette repair fund since I was dumb enough to trust the reliability of GM products and did not get the extended warranty.
If I drove my car harder, this would have happened years ago...and maybe catastrophically.
Old Mar 9, 2011 | 03:55 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
This car is meant to drive hard. Many people on this forum race thier cars often. The harmonic balancer is just one of those things, but not too serious.
I would go get the car and go to a reputable Corvette shop. There may even be a sponsor of this forum in your area.
Good Luck!
Old Mar 9, 2011 | 05:11 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Take it to someone who KNOWS how to replace the pulley...it shouldn't cost an arm and a leg like some places say it should.
I had mine swapped for $150 bucks in a few hours
To harmonic balancer
